Question about Kitchen Ranges
I HAVE A FRIGIDAIRE SLIDE IN RANGE AND WE HAD A POWER FAILURE. NOW MY RANGE BLINKS F30 AND I CAN'T GET MY OVEN TO WORK.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
There are (2) resetable thermostats in this particular oven, the first is located on the rear of the unit behind the panel ( if standing behind unit its in the upper left hand side of unit. 2 wires leading to the thermostat and a small "buton" to press to reset it. if it doesnt work after resetting that one then the second on eis located under the control panel behind the second burner knob from the right.. to acess this pne youll need to remove the burner knobs::: then loosen and remove the plastic hold down under the knobs, the contriol panel will lift off thenand then remove the 4 \screws holding hte clock assy in position, when thats lifted out of the way( no need to disconnect)you see hte same resettable thermostat moundted on the unit rigth behind that second switch, simply reach in and reset it...TURN POWER OFF PRIOR TO EITHER REPAIR LIVE WIRES!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on May 08, 2008
Frigidaire gas stove, oven will not work. Shows F30 code
That is an error with the temperature sensor.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on. If you still have the problem here is a link to order the replacement part and a video how to replace the part which is fairly easy to do.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/561286-error-f30.html
Dec 10, 2016 | Frigidaire Kitchen Ranges
How do i fix an f30 error code on my frigidaire range? it only beeps when i try to turn on my oven... and shows f30
Sorry to read about your problem, I hope this helps you out.
You have a shorted keypad membrane.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Microwave Ovens
Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire Professional Series Range - F30 ERR
door will not unlock after cleaning
Jun 11, 2009 | Kitchen Ranges
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Jul 16, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire range
what is the model number
May 07, 2008 | Kitchen Ranges
Kitchen Ranges Logo
120 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
