Question about Maytag Neptune FAV6800AW Top Load Washer
MY nEP[TUNE WASHER WONT STOP RUNNING WASTER - Maytag Neptune FAV6800AW Top Load Washer
  • Maytag Master
  • 909 Answers
Ok there are 2 possibilities that cause this problem. 1) If the drain pipe is placed to low, the water will not stop draining. It will just carry on coming into the machine and just flow out again. Make sure the pipe is at least 3/4 the height of the machine before that draining will stop. 2) If you switch the power off on the washer, and the water still comes into the unit with the power switched off,then the water solonoid needs to either be serviced or replaced. With the plug pulled out, undo the 2 water pipes connected to the water valve assembly.Once removed, open the individual valves and clean them properly. once cleaned, reassemble and retry. Either of those 2 must work. My bet is the water pipe is to low. lift it up a lot higher.
Posted on Aug 29, 2010
SPEED QUEEB AWS17NW HOW DO I INCREASE SPIN SPEED IT SPINS WAY TO SLOW CLOTHES ARE STILL WET
Well could have a bad motor, and depends how much are you loading into it. Remember the more cloths you put in it and all that water collects in the cloths and weighs it down. Try a Smaller load! Unless this waster is a HE Washer it wont.
Sep 28, 2014 | Speed Queen AWS17NW Top Load Washer
When hot water goes in tub waster makes norris kenmore waster top lead model 110 serial # c 80207234
Try adjusting the water tap for the hot water. Open or close a little while it is filling up.
Jan 23, 2011 | Kenmore 23822 Top Load Washer
No pressure just normal water flow with motor running
water comes out slow, in the soap cycle, waster ooze out
Apr 15, 2010 | Honda Pressure Washer PSI 3000
I have LGwm2016cw.. i get no error code. the washer wont stop adding water and it wont drain the water. any ideas
A small tube running up the side of the tub carries air prussure to tell the machine to stop filling.Mos likely the hose has disconnected.
Mar 21, 2010 | LG WM-2277HW Front Load Washer
Help. My washer wont drain but it will spin kenmore model 110.26292693
Please take the waster pump off and check the inside of the pump to see if there is anything foreign inside stopping the water from coming out.
Nov 12, 2009 | Washing Machines
Kenmore washer leak
With the machine unplugged and EMPTY disconnect the water and waster water connection from the wall and tip it forward you should then be able to access the pump.  Check the hoses running to the pump. (usually white plastic with 2 large and 1 small hose running to it.. you can also just move it away from the wall with it completely connected and run it thru a cycle to see where it is leaking from.
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
