Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printing addresses on labels
Addresses print halfway off the label. They always used to.
  • kiboko May 11, 2008
    Sorry, I don't understand your instructions. What is printers section? How do I set parameters?
  • Anonymous Mar 20, 2014
    the first line in the address label is not printing. what can I do to fix this
    Genius:
  • 1,224 Answers
Did set the parameters in the system before printing labels you can make a new printer control in printers section to only be label printed with the same printer you use
when you goto print click on the new print control that you have set for labels this way your software wont get the big confusion of paper or labels
Posted on May 07, 2008
  • Christophe Thompson
    Christophe Thompson May 11, 2008
    http://h10032.www1.hp.com/ctg/Manual/c00...
    heres the manual sorry bout the other night my signals got crossed
    goto start
    goto control panel
    goto printer set up
    goto set new printer up page
    add your same printer to the list of your printers
    select how you want your printer to labels or papers
    haveing 2 set parameters for printers helps to distiquise what print job you will be doing
    paper printing should be default always
How to print envelop on HP 3390
you would be better using sticker sheets.
see for an example
http://www.officeworks.com.au/shop/officeworks/c/office-supplies/labels/address-labels
your local office supply shop would have something similar
Some labels have downloadable templates to make it easy to line up the addresses to the laser label sheets
Trying to print on the envelope could cause jams inside the printer
Aug 13, 2016 | HP LaserJet 3390 Printer
When I print a label I have to press the feed button to get the label out. How do I get it to push out the entire label without me having to feed and reset the whole time?
Most people I know print addresses from a sheet of labels, which ejects at the end. It sounds like you are printing one address from a continuous roll of labels, and they are so close together that the printer cannot push it out for you without misaligning the next one. I think both systems are designed mainly to print a batch of labels at one time.
If you are printing a batch, it is best to prepare the whole set first and save it as 'data' for printing addresses. For a one off or just a few I would use a sheet of 24 labels (say) with 3 to a row, and 8 rows.
Does this help?
Jan 06, 2014 | Argox OS-214 Label Printer
I have an Access file with 132 names with addresses. I want to print them on Avery labels. How can it be done?
Avery labels have an ID# that when entered into the Avery site will supply you with the page format for your Msoft Office software.
Dec 14, 2011 | Avery 5160/8160 compatible (100 White...
How to download programe to print labels
Easy Label Printer is a simple program for printing addresses on to sheets of labels, and the only one, as far as I know, to print addresses directly from the Windows Address Book (XP) or Windows Contacts (Vista).
Here is the link
http://www.tucows.com/preview/370301
At that page, Simply click on the "DOWNLOAD NOW" button, and when asked to save or open, SELECT & Click on "OPEN"
After the download finishes it will ask you to confirm opening, so click OPEN.
The Label program will begin installing.
After installing find the program in your programs listing menu and start it up.
If you need help with the program itself click on the menu item "HELP".
I hope this helps, if it does please consider giving me a good rating as this is the first "HELP" that I have answered here :-)
& Good Luck!
Sep 17, 2011 | Microsoft Computers & Internet
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
I have an I Mac 10.58. I have typed into an Address Book 62 addresses that are stored on an Address on an a group labeled "Xmas Group." Separately I have typed into "labels" the #8167. What is the...
Have the group selected and then select print from the file menu.
Make sure that the arrowhead next to you printer name is pointing upwards.
Under the from to page selector it should say Address Book.
Below that is should say Mailing Labels
On the next line down select the 'Layout" tab.
Check that you have selected US letter then select 8167.
Then hit print.
That's all there is to it. I just tried and it printed 4 columns of 20.
Dec 20, 2009 | Computers & Internet
Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
Oct 14, 2009 | Zebra TLP 2824 Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
Import information from a spreedsheet
use the "print from a database" function that the software for the DYMO has. It will allow you to import a database (in this cae your excel spreadsheet) and "map" it to the fields on an address label, like first name, address etc.
Dec 02, 2008 | Dymo LabelWriter 400 Thermal Printer
Lexmark 125 Prints Labels with color cartridge
I kicked the **** out of it and it started to print. I don't recommend it if you are afraid you may damage the electronics. The way I saw I spent damn near 70 dollars on some useless print cartidges nothing was wrong with them. The error message kept saying ADD CARTRIDGES. Anyway I'm thinking about a new printer anyhow.
Aug 28, 2008 | Lexmark X125 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
297 people viewed this question
Ben Johnson
