Fan comes on for 10 sec. trys to start but stops,i unplug the power and try again same thing .It would it do it once every 2 months ,but now it will not stay on. please can you help me bruno
  • 17,130 Answers
Possible that the relay or the compressor relay is switching off in load. If there is cooling onthe compressor but cuts off without a reason then shcek if the thermostat is kep tlow to let the trigger cut off. set a temp just above the room temperature.If the compressor holds on till the set temp is reached the thermostat is working fine. otherwise the thermostat may be givng the srong signal so that the compressor is not swittched on.
You can bypass the relay drive to switch on the compressor to chech this circuit. If so get the auto circuit corrected.
Posted on Aug 29, 2010
The blue & red lights on my JVC HD-56G787 tv are blinking alternately
Or the problem could actually be a power supply failure
Nov 08, 2013 | JVC HD-56G787 Television
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
HP DV6700, power keeps switching off after 2-3mins from switch on. Fan does not come on and core temp rises above 90 deg. celcius prior to shutdown. Tried unplugging battery and power then holding power...
I have the exact same problem...only started 2 days ago...let me know if you find a solution. I wanted to clean it from the inside but you have to take the whole thing apart,and I am not comfortable doing that
Nov 15, 2010 | HP 6700
32'' Vizio won't work
It is under warranty, I would take it back and ask for exchange, bad sign that it goes out in less tahn 30 days.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 11, 2010 | Vizio L32 32 in. LCD HDTV
Power light comes on,fan starts then shuts down nothing hapens but power light stahys on.
try draining the battery first.in order to do this. batery should be taken out the laptop. power adapter is unplugged. press and hold the power button then counte 1 to 10 then release your finger after 10 secs. then press in again then count. do that for 3 times. plugged everything back in and monitor the status afterwards
Mar 06, 2010 | Lenovo 3000 N200 Notebook
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Power light is on, and nothing happens.
The RAM may have been "jammed up" when it was put to sleep. You said you powered down completely and then started up again. How long did you leave it before turning it back on? Try it again, but this time, unplug the adapter from it and also take out the battery so there is absolutly no power going to it. Leave it like that for about 5/10 minutes and then try it again.
Hopefully that will help you out
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Router reset
the power light of your router should go flashing once it's being reset. If it is not doing that you can try this reset.
Hold the reset button for 10 sec. while holding the reset button unplugged the power of the router, wait for another 10 sec (still holding the reset button in), plug the power back and wait for another 10 sec. and now reslease the power button.
If it still won't work you can also do a software reset with the latest version of this router, You go to the setup page and go to the administration tab and go to the sub tab that says factory defaults, just tick yes and do save settings.
Hope this one helps.
May 09, 2008 | Linksys Wireless-G WRT54G Router
WRT54gs' internet link wont come up
Here's a couple of places to get started:-
1. If you're on the internal network, try logging into the router's admin page, and iff you can see link to the cable modem / DSL line "Internet Interface". Try Refreshing DHCP on that interface.
If it's not looking great, or it's not serving out DHCP, do a quick powercycle on the LinkSys and see if that clears it (I would guest you've tried this though!)
2. Check your cable modem / DSL line box and ensure that all its lights are as normal (Without Make / Model etc I can't help you in detail there.
3. Try powering off your cable modem / DSL box and then your link sys. Wait 10 minutes (Yes, that long, there are reasons for that involving the upstream network). Powerup you Cable Modem / Link Sys box, once that looks healthy (Maybe 2 minutes to boot with some models) power up your LinkSys and see how things look then.
If you're still not having luck, unplug the power from the LinkSys again. Press and hold the "Reset" button, keep it pressed, and reapply power. Count to 10 before letting go. Wait a second or two, then press and hold the rest button again for another 10 secs. See how it looks then.
4. If all of the above doesn't help, call up your ISP and ask them to run a diagnostic on your Cable Modem / DSL Modem.
5. If you CAN get to the web page on your LinkSys, and you KNOW the cables are good then you should try putting the original firmware back and see how things go then.
If you're still having issues after all of the above I'd suspect you have faulty hardware.
Nov 16, 2007 | Linksys WRT54GS Wireless Broadband Router...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
