Plasma tv I have a plasma TV Philips model no: 50PF7320A. The symptom is the unit has audio but no video(no light on the screen)
  • villacom May 19, 2008
    Thank you,for helping me. One of your experts ask for more information about the Philips tv model no: 50pf7320a. the tv has audio but no video(no light on the screen), the screen is good and I change the small signal panel already.
    Scholar:
  • 72 Answers
Ok first i have to ask when u turn sound off on TV and get close to the TV does it make a buzzing noise ? If so u have a damaged Plasma panel .
If this is not the problem you could have a bad logic or y-main (most common problem) will need to perform a white screen test on the plasma panel to verify this is the problem.
This is what u need to do
1. Remove the back panel of the TV.
2. Remove the Small Signal Board bracket ( the two long bars on back of the plasma panel, the bracket that is connecting the two with SSB on it, remove this and disconnect the connectors to the power supply (CN1M02,CN1M03, CN1M45)except for the main power plug in you will still need this)
3. Once u remove the SSB bracket you should see a plasma panel resembling pic 1.
4. Place a jumper wire or connect the two pins (CN 2012) on the logic board located underneath the SSB bracket.
5. Also place jumpers on the power supply (J8003 and J8004)
6. Now plug in the power supply, U should hear the relays click and after 5-10 sec you should see a green led on power supply, and 2 green leds on logic board 1 will be solid and 1 will flash.
With this set up you should get a white screen on your TV this will let you know if the panel is bad or not.
Also forgot to ask have u had this TV worked on recently or this just happen for no reason.
Posted on May 10, 2008
  • James Peters
    James Peters May 10, 2008
    General picture of a Samsung plasma panel (50HDv4)
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
Hello, i have a 50 inch philips flat tv model # 50pf7320a/35. why is the screen half black?
Unfortunately, i have found in my experience is when this problem occours you need to replace the plasma panel, which can be a costly thing to do and takes a little bit of planned time. Other than that you can try to replace the X-sus printed circuit board or the Y-sus printed circuit board. Those two boards control the screen circuitry, Good Luck.
Sep 26, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips tv blinking red light
I've seen this problem before with Philips. 6X3X blink was the X-sus or Y-sus boards. In other words, the TV cannot make the picture on the screen properly, so it won't even try and will shut down.
I've also had difficulty getting these parts from Philips (even while being an authorized service center). If you have an authorized service center near you, you might want to give them a try because I don't believe they were too expensive, just hard to get.
I hope this helps you...
Jan 08, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
http://www.tivocommunity.com/tivo-vb/showthread.php?t=319984
Oct 16, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox rear projection tv mn 9p5514c101
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
810 people viewed this question
Top Televison & Video Experts
