Question about Samsung Exclaim M550 Cell Phone
Phone keeps cutting on and off after about 45 seconds of being on, I think there is some minor water damage but I don't know where it came from. Is there a way to stop it from cutting on and then going back off on its own? P.S. It only works when I put in the charger and turn it on, and even when it is on the charger, it cuts off on its own.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Simple reason is that its due to the softare failure.Its better Re program the device.
Posted on Aug 29, 2010
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Tip
How to Use a Pogo Stick
If you've never used a pogo stick before you might think it looks really hard, but don't be put off - once you get the hang of it, you will have a great time using it.
You have to be patient. At the beginning you may only manage around 40 jumps but within a week you should be doing a lot more.
Here are some tips for getting started:
Find a smooth surface that is flat, i.e concrete. Don't try using it on grass or other bumpy surfaces.
Keep the pogo stick straight and steady and put your feet on the pads either side of the stick.
For beginners the easiest method is to place one foot carefully on a pad and then as quickly as possible, bring the second foot up on to the pole.
Once you get more confident there is a method where you can grab the handles and jump both feet onto the pads at the same time.
Don't be tempted to push the stick away from you or you might hurt yourself or damage your pogo stick.
Keep the stick aligned with your body and start jumping.
Don't get carried away! Don't jump too hard - just enough to keep the movement going.
If you feel like you are going to fall, lean slightly towards the opposite direction but not so far that you fall over.
Once you have mastered these basic moves you can move on to learning tricks
Good luck and have fun with your new pogo stick!
on Aug 20, 2012 | Sport & Outdoor - Others
Starting issues after fueling
Sound like water in your fuel tank. Get heet and try that.
Feb 22, 2014 | Cars & Trucks
While cutting a 2x4 at a 45 degree (small load) the motor quit after 12 inches. seems like i should be able to rip a 2x4
How would you rip 12 inches if your riping a 2x4 on a 45 secondly the blade of that saw and weather or not you were cutting through the grain on treated lumber. But if all that has been checked chances are one of the brushes on the motor need replacing. there are usually 2 black caps on both sides of motor that have replaceable brushes if one stops making good contact you get half power when cutting. You can check them and or replace if needed.
May 06, 2011 | Jet 707000 B3NCH JBTS-10MJS, 10" Jobsite...
Key pad fails - has had minor water damage
there is a little circle under the back of your phone. if it is white, it meants you should talk to at&t about a replacement. but if it is red it means your phone has major water damage and they will not give you a replacement. i had the same problem and had to throw the phone away.
Jan 11, 2010 | Motorola Mobility RAZR V3
I dropped my phone in tea, the phone still works but you cannot see anything on the display screen. Is there something I can do to fix it. Sony Ericsson Walkman W350a.
Short answer: No. Long answer: Your phone has water damage. Warranty is void if your phone has water damage. Since you KNOW you've dropped it in tea, you should consider it a lost cause and move on. For others - if you do something similar (dropped in water): Immediately turn it off. Take the battery out, then proceed to completely dismantle the whole phone. I have in the past used kleenex paper to tuck into places I can't dismantle, to get the water out, but they usually say to dismantle it, then let it completely air dry. It may take a week. If it, after it's completely dry, still works, then maybe you got lucky, and maybe it'll start acting up in a while, problem by problem as the electronics corrode inside the phone. I have heard of phones surviving water damage with only minor problems, but it's rare.
Jun 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My nokia 7610 phone has been dropped in water
You should detached quickly its battery first. It is to prevent further damage to your unit. And dont try to power it on. Then bring your unit to a cellphone shop to have it dry and clean it for you, they will sometime automatically charge for water damage repair.
For minor damage only battery pack will get damaged. Luckily only cleaning and drying will get it running.
Apr 17, 2009 | Nokia 7610
SIDEKICK 3
Do you want to know if it's your cp is still working?
First, make it sure it's totally dry without any water or moist before turning on the device.
Second, if it's OK and you know it's out of water inside and the cp was total dry, turn it ON.
Third, if you're not sure and you don't want to take the risk by turning it ON, it is a better option for you to bring it into any cp service center near you.
Cheers
Feb 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Samsung Exclaim M550 Cell Phone Logo
98 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
