Question about Yard Machines Garden
I have a 13.5 hp briggs and stratton that had got gas in the oil and i changed it. stars good and runs perfect cold. when it worms up the throttle stops working it will only run at high idle with no Chang when throttled down. starts blowing black smoke and stats running ruff and would die. checked the float and there was as small pebble by needle valve i removed it seems that it helped. **** still doing same thing **** stays running until you putt a lode on it then dies.
  • 333 Answers
Float isn't working. It is leaking past the needle. Try taking the float out and use a q tip to clean out where the needle valve go's. And inspect the rubber tip carefully. If it has any mis shape or grove. Get a carb kit and rebuild it. That would be the thing to do in the first place. because the gas bypassing the piston and going into the oil will be enough for you to get a new motor too.
Posted on Aug 29, 2010
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
Jun 23, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a b/s intec ohv 13 hp oil has gas in it ,oil would fly out the exhaust. I drained the oil out and much gas is evident. Engine has good compression. Oil was squeaking out in late summer and i...
If you have that much gas in your oil it's usually because the float valve in the carburator is stuck open. This allows gas to overfill the carb, it then goes to the cylinder and is thin enough to get by the rings and into the crankcase. It could be because there is something in the valve seat keeping it from closing or the float could be damaged.
Jan 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
WhaT TYPE OF OIL DOES THE 16.5 HP B&S engine take
Your 16.5 hp Briggs engine takes SAE HD30 weight motor oil. I recommend to use a name brand high quality oil. It should take 48 ounces from a complete drain. If you run this engine when it is cold outside (below freezing) then you can change to a 10W30 oil.
Good luck
Sep 16, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My propane generator engine has apark and gas
For a quick test.
Check engine oil.
Remove wire from low oil sensor and see if it starts every time.
If that works change oil and replace low oil sensor.
Hope this tip helps to solve your problem.
r/
David
Jan 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Gas in oil 12.5 hp briggs and straton will not start
the float in the carb is stuck open, its flooding with gas. the gasoline is going past the rings and/or valves into the crankcase. you need to remove the float bowl and unstick and reset the float to specs, maybe a new seat and needle and change the oil before restarting.
Jul 26, 2009 | Briggs & Stratton Garden
Garden Logo
235 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
