Question about Kenmore Washing Machines
My kenmoore elite oasis has an error code F50 when i try to wash
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F 50 flashes when the motor rotor position sensor (RPS) senses no rotation (Motor Stalled). Does basket turn freely? If not, make sure bottom shipping pack has been removed. Remove the basket and look for foreign object. If basket turns freely, then perform the below mentioned diagnostic test--
Motor Circuit TEST
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following step assumes that this step failed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
What is F1 failure code on a kenmoore oasis washer
check your owner manual section troubleshooting for error code very important.
Normally this error code can be meansL a) pressure out of range.
or b)eepron error.
or call the factory and get support online via chat or phone for to fix it.
God bless you
Sep 25, 2012 | Kenmore 4.7 cu. ft. High-Efficiency Top...
My Kenmore Elite Oasis HE is flashing a code "F50", can you tell me what the error code means?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Oct 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis HE model # 110.2706 stopped working during the middle of a load and showed an F 50. Tried to unplug it, restart it and tried the clean machine mode. Nothing is working.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
Washer won't start spin cycle, error f50
The F50 error on the Whirlpool Cabrio / Kenmore Oasis points to the basket and possibly some obstruction keeping it from turning freely.
Please see the following PDF Service Manual for the Whirlpool.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F50 alarm on my kenmore oasis washer
Sep 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis he top load washing machine f 50 code
Aug 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE top loading washer model #110.27082602 gives me error code F50 and doesn't spin. Other blogs tell me that it is possibly a main control board. What do you think?
Mar 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Ellite Oasis - model #27042603
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
KENMORE ELITE 2709
Dec 29, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
313 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
