Question about Encore 10/100 FAST ETHERNET 8-PORT SWITCH (852189001275)
Switch connectivity Hi, I have two small switches connected to a wireless router. All of a sudden this morning, the wired portion of our network (the portion that uses our switches) went out. No connectivity. I know it's the switches and not the router because those of us that have wireless, get get out to the internet no problem. My question is, can I log onto or get into the switches to diagnose to problem. I've done all of the obvious things - turned everything on and off etc. Help!
  • 61 Answers
Depending on router brand you may be able to log in and check that wired portion is enabled...look carefully at documentation for instructions. I had a similar problem with a D-Link Router and found the info for enabling wired connection at their website. Another problem I had one time was ( believe it or not ) one of my cats has a **** for chewing on wires !!! It was an easy fix after figuring out the problem. Cat is now at SPCA ( just kidding )
Posted on May 07, 2008
Hi, ADSL2+Wireless Modem Router was set up, it was good, but without the yellow cable, it was not connect to net why? Thanks, looking forward of your reply.
Because you need to match the security setting on the wireless router to sign on to the wireless portion of the modem. If you flip it over, you should see a sticker with WEP on it- write that down, view available wireless networks, and enter in the key from the sticker when prompted- at that point you should be able to use the wireless portion of the modem
May 31, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Hi I need to connect more wired devices than the 4 port allow. Is ther any instructions? Can it be dome?
Yes you can connect more wired devices to it but you need to get another networking device like a HUB or SWITCH which will be connected to one of the port of the router then go get the hub or switch with the number of port that you will needing like a 24 port hub or switch.
Then once you have that HUB or SWITCH you can simply connect that to one of the port of the router and connect you wired devices to that HUB or SWITCH.
Jun 17, 2010 | Belkin Wireless-N Wireless Router with...
I'm trying to turn the wireless function on my D-Link DGL-4500 Wireless Router. I go to Basic > Wireless then check the turn on wireless radio button (put in the setting and all that) then hit Save...
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Jul 13, 2009 | D-Link DGL-4500 Wireless Router
Wireless Router to Computer connection problem
Look underneath the bottom of the laptop. HP is known for putting the wireless toggle switch under the laptop, to keep it out of the way. But that also keeps people from finding the switch to wireless, from wired.
I'd bet your laptop works if plugged into the network with an RJ45 cable.
Jun 20, 2009 | NetGear WGR614 Wireless Router
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
I am unable to connect through wirelss
You may need to go in, and configure the wireless part of the router.
From a wired computer, try going to http://192.168.0.1
This will allow you to configure the wireless portion.  The manual that came with your router will have your default admin username and password, as well as the instructions on how to configure the wireless part of the network.
Mar 19, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Router issues?
If you haven't made any changes and suddenly your wireless connection has stopped working than these are the signs that your router is offline.
Now first of all check that on your router have you got the dsl or the internet light solid if it's not solid then it could be a problem with your broadband line...check with your isp whether the signals are there on the line or not.
Now, if the signals are there then...
1) Do a complete power cycle of your router unplug all cables from your router replug them then check....
if still you are not able to open up any pages on ie...then reset your router to default settings...
in order to reset your router at the back of your router you will find a small hole that is the reset hole press the pin in that hole for 10secs that will reset your router....restart both of your comps....
Now, if you are using windows xp then
click start>control panel>in control panel click on switch to classic view>after that click on network connections>
in network connections you'll find wireless network connections....right click on wireless networks..
then click view wireless networks you'll get an option of belkin wireless network..select it and press connect....
once it says connected close all the screens and run the router installation disc that you got with your router .....you will be able to connect..
If you are on windows vista then
click start>then in start menu click connect to you'll find belkin network select it and press connect once connected run the router installation disc...
Feb 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get online or pick up a wireless network?
A couple of issues and questions
First generally a wireless router in installed onto a network either to the ISP's modem or to another router that is connected to an ISP's modem it is not connected on the wan side to a computer (unless that computer is acting as a firewall or proxy server to the internet). Computers are generally connected with a wire to the (optional) switch portion of a wireless router or wireless connection.
Have you tried testing with a computer wired to the router to assure internet access is possible without worrying about wireless issues?
If you are considering encrypting the wireless router did you test it unencrypted first to assure the unencrypted radio transmissions work?
Is the wireless communication encrypted for other computers you own and possibly not for the HP you are now trying to connect?
Are you sure the distance between the wireless router and the garage is not an issue. Perhaps you could test and configure the connection in the room with the router and when it is working move it to the garage.
According to the product specs for the HP Pavilion it has built in wireless B & G you did not include the router manufacturer and model does it operate on the either wireless B or G?
Dec 08, 2007 | Computers & Internet
Encore 10/100 FAST ETHERNET 8-PORT SWITCH (852189001275) Logo
118 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
