Question about Samsung CLP 300 Laser Printer
Samsung CPL-300 Color Laser Printer Problem W/ Labels
I Just purchased a Samsung CPL-300 Laser printer.
I have attempted printing color dvd labels w/ poor results.
The label mfg. states they are compatible w/ all laser printers.
They suggested that I change the paper setting to labels or transparency in order to adjust the fusing.
I tried both settings, neither produced good results.
The surface of the label comes out of the printer w/ small bubbles on the graphics area; after cooling/drying the ink then comes off the label.
It appears that the printer is too hot.
There are no suggestions in the Samsung manual, which by the way, you must download fron their website as a pdf file as no manual comes w/ the printer.
  • 2 more comments
  • vbgunltd May 14, 2008
    I tried that w/ the same results.
  • greenhat Jul 25, 2008
    Same prob w my CLP300. Most (but esp. dark green, dark blue, brown) colours come out as if too wet and bubbled/smudged on my labels. Toner simply brushes or blows off paper. Toning down the intensity of the colours works - light green, yellow, pink etc are all fine. Specs from Samsung say labels should be 120-150 GSM, 32-40 Pound Bond and 100-250 Sheffield Smoothness. These are very heavy papers and prob. expensive. Setting the paper type to 'thin' seems to work OK - prob. telling the fuser not to overheat.
    Hope this helps.
  • Bill Vernor Feb 27, 2009
    I have encountered the same problem with printing CD labels. The ink just smears on the surface and I get nothing I can use. Has any one found any labels that actually print correctly when running through this printer?
  • Reiryu Mar 06, 2009
    I have a similar problem, but while printing on card stock... it's like it just avoids printing in a certain spot each time. the area around the blank can sometimes flake off a bit more too.
    Yes, I've changed the settings to card stock.. but it still misses that spot. It works completely maybe once in 34 prints, if I'm lucky.
    I'm wasting paper, time, ink... ooh, the frustration.
I have a similar problem and whenever i encounter it, i just tone down the contrast of the image then it prints out fine. hope that helps.
Posted on Jun 02, 2008
    Problem Solver:
  • 10 Answers
I had the same problem bu this was using a more glossy paper not a label, the Sansung helpdesk adviced i try a different brand of paper and /or change to a matt paper finish, so are you usign gloss labels if so try the matt finish
Posted on May 22, 2008
I work in the comercial printing game, what your describing sounds like the surface finish used on these labels is only suited to black toner. Black requires the least amount of heat to set, where as colours require more radient heat the lighter the colour gets from black. Try printing a black/monotone lable and see if you still get this blistering problem.
Posted on May 09, 2008
Epson Artisan 1430 How do I print labels onto CDs?
Hi Joe
for most printers there should be a print cd label option in the Software that comes with the printer
install the Software and go to label settings >>CD label
Mar 23, 2014 | Epson Artisan 1430 Wireless Wide-format...
Brother HL-4040CDN Laser Color Printer Printing Quality Issues
Hey Robb, Laster printers don't have print heads dummy, that is for inkjets. Just close your mouth if you don't know anything.
Dec 03, 2011 | Brother HL Office Equipment & Supplies
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Problems with image when printing onto laser labels.
This article might not solve your specific problem with that printer but will give you a list of possible solutions http://blog.worldlabel.com/laser-labels-everything-you-need-to-know
Nov 02, 2010 | Samsung CLP 300 Laser Printer
I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Apr 15, 2010 | Samsung CLP-500N Laser Printer
How do you print Glossy Photos on a Samsung Color Laser CLX-3160FN printer without the laser buring off the gloss?
Do you have the right type of paper? I suspect the glossy paper you have is for an inkjet and is melting/buring when it is going through the fuser of your laser printer. The same thing for sticky back labels. Unless they say they are rated or compatible with a laser printer, don't use them.
Jun 20, 2009 | Konica Minolta magicolor 2500W Laser...
Flaking ink
no funciona no se ya esta conectada pero dise que conecte el microfono
Oct 17, 2008 | Samsung CLP 300 Laser Printer
Vista turns color to b/w...
Ianrbland: wHEN YOu choose color make sure to type a name in under Favroties, It should say untitlyed to begin with and after you close and open it will say defult, just choose color and type in a name such as Color and hit save as favortite
Jun 02, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
676 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
