My syastem was working properly since five month don"t no suddenly what happned after swiching on the computer its showing like DISK BOOT IS FAILURE, INSERT SYSYEM DISK AND THEN PRESS ENTER ....... i amnot getting what to do for this problem? my system model 591s samsung syncmaster....... please if you have any idea plesae send a mial to geniusmuruli@gmail.com
  • 629 Answers
This means, there is no bootable disk detected. Make sure there is no floppy drive inserted to the system and remove external storage devices, then try to remove and reconnect the hard disk. Make sure your boot method is set to use the hard disk with your OS installed. If this does not work, you may have to reinstall your operating system. If this fails, it may indicate a failed hard disk and you may have to get in touch with your vendor for warranty replacements if needed. hope this helps.
Posted on Aug 29, 2010
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
Aspire One N214 Model # ZG5 keeps showing me a Acer screen before informing me that I have a Media test failure and that it has no bootable device. I have no boot disk it asks for, Please help me!
The media failure means either the hard disk has failed and therefore cannot boot up the notebook.
Try reseating the hard drive first, so it makes proper electrical contact. If it still fails to boot up, then go to the BIOS setup and check to see if the BIOS detects the hard drive. The BIOS may have a hard disk diagnostic program, if so then run this program to check the hard disk. If the hard disk is faulty, then a new hard disk is needed and install Windows on this hard disk plus the Acer's device drivers and your programs to get a working computer again.
Sep 10, 2010 | Acer Aspire One PC Notebook
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
My computer won't start, the creen shows Disk Boot Failure, Insert System Disk and press enter. F10 doesn't work either
it means that you may have a corrupt/deleted windows, check your hard drive if it is working properly, if the hard drive is fine, then re-installation of windows is needed, or if you have a recovery disc use it to repair your windows
Nov 23, 2009 | HP Compaq Presario SR1550NX (PY059AA) PC...
Suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
Aug 07, 2009 | Averatec Laptop Keyboard for 3200 Series
Got off lease also, with no OS it won't boot
You may not install a working Hard driver from one compuyer to another unless every component is exactly the same. All windows OS look at the hard ware to stop a person from  moving an OS for one syastem to another. Reinstall the OS of you have the disk,or use a free OS or co to the website and get a reinstall disk if a name brand computer that came with an os.
Jan 20, 2009 | HP Compaq Business d530 Small Form Factor...
Initially disk boot failure now White screen but runs in oter mon
Try checking inside the computer for loose wiring near where the power supply box plugs into the motherboard, make sure that you turn the computer off and remove it from the outlet before opening it. While the computer is open, check all of the leads going into the motherboard are pushed in gently but firmly. Remove the RAM clean it with a soft paintbrush and then return them to there slots ensuring that they are seated correctly. Do the same with the graphics card and sound card if you have them in PCI slots or AGP slot returning them correctly into thier slots.
Put everything back together and before powering back on make sure that the power leads going into your PC and into your monitor have not been damaged in any way. Reboot your computer and try again. If you still get a shock or your computer does not boot properly then you may need to change the power supply box.
I hope this helps
Dec 15, 2008 | Acer AL1717 17" LCD Monitor
Disk boot failure
sounds like a hard disk drive problem. If you are comfortable with working inside your computer, you can open the case and remove the cables to the hard disk, and re-connect them again firmly.
Jul 07, 2008 | Computers & Internet
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
