M6504w servis washing machine
I 've lost my user's guide,please advice how to lesser the washing time,i think the setting are all set in 40 minutes each wash, it consume to much electricity and money
thank you
watugot
  • 290 Answers
SOURCE: Washing machine defaults to clean washer option
Sounds like user interface board. Try unplugging the machine, press power button for 3 seconds, plug machine back in and try again. If this does help, it will probably be a temporary fix. The user interface board is the one mounted directly to the console.
Posted on Sep 25, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
FitzOriginal
  • 842 Answers
SOURCE: Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
SOURCE: Hoover Quattro AS110 001 - no settings info!!
http://service.hoover.co.uk/manuals/pdfs/AS110.pdf
Posted on Jun 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: I am looking for a user manual for a Servis wahicg
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Posted on Sep 16, 2010
Lost manual dont know how to set up settings.
You see, I've found this general user guide for the Galaxy S.
Hope it might suit your needs, somehow.
Anyway, please, let me know if you need additional informations.
Regards,Carlos
Nov 02, 2011 | Samsung Galaxy S GTI9000 Smartphone
Servis 7kg 1500 AA - bush's and motor, ok and
relay is stacked so you start the machine off position power on the wash butten you will check this method
Sep 13, 2011 | Washing Machines
I need to set the time in my Armitron 40/8105gry. I lost the manual and have no idea how to set time. It is to confusing so please send me a description of how to set the time.
You can find Armitron Watch Instructions at the Armitron website. I've included a link below for your convenience.
http://www.armitron.com/watch_instructions.asp
I hope this helps. Please let me know if I can be of further assistance to you.
--Sandy
Please be sure to Rate this message! Thanks!
Apr 30, 2011 | Armitron Digital Sport #40/8105GRY Watch...
LOST INSTRUCTION MANUAL
HI,
You will have to buy the user manual for your model from the below link.Just copy paste the below link in your browser and load it.
http://www.manuals-in-pdf.com/advanced_search_result.php?keywords=download+user+manual+for+Whirlpool+AWM+8103/1&forward=plist
May 15, 2009 | Whirlpool AWM8103/1 Front Load Washer
I just bought a house and the previous occupants lost the zanussi guide for the washing machine. So I do not know the washinh settings.....e/g 40 degree wash etc...... as it is all in letters of the...
Try this link to see if you can download a user manual http://www.zanussi.com/
If you can provide the specific model number..and cannot find it at this website.. let me know...
Hope this helps
Sep 21, 2008 | Zanussi Washing Machines
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
