Question about Refrigerators
Freezer not getting below 30 Dig frosting right at the thermocouple and has frozen and popped the top off so I replaced it and the timer but did not fix the problem all fans are working and all the coils are very clean hope you can help.
  • 1 more comment
  • Ronnie Short Aug 29, 2010
    I thank I will ask for a refund I have none of these problems
  • 28 Answers
Either you have a very severe air leak, or you will see a frost ball at thr enterence from the small line coming into the evaprator in the freezer. If that is the case: a appliance servicer will be required to find out what is wrong with the compressor system.
Posted on Aug 29, 2010
  • mark1468 Aug 29, 2010
    The compressor on your fridge is designed to operate a 0 Deg F in the freezer compartment. If the fans are running, the compressor is running, and you are only achieving 30 deg F in the freezer compartment. It is clear that you have an issue with the sealed system and require an authorized servicer to repair the unit.
Frigidare refrigerator model#frt17g4bwd sealed system leak warranty
It is possible that the refrigerator is unable to defrost or for the water from defrost has frozen and blocked the drain inside the back of your freezer. Unplug the refrigerator and remove the freezer panel listed as location number 10 in photo HERE
Once you remove the rear panel I want you to tell me what you see. Is the drain opening frozen over?
You may need a=> 242044007 Defrost Heater
depending on what you see behind the freezer rear panel. Are all the coils frosted over? Also I need you to turn the defrost timer inside the fresh food section and listed as location number 23 in this photo HERE
By turning the timer clockwise slowly until compressor and fans stop is putting your refrigerator into defrost. Leave it in defrost up to 30 minutes and if the defrost timer does not turn compressor and fans simply turn again slowly to start again. If you need to turn timer after 30 minutes the timer will need to be replaced. The part number for the timer is=> 215846602 Defrost Timer
Here is more on=> Leaking Refrigerators
Please ask questions and I will be here to assist you Thanks Sea Breeze
Jan 04, 2013 | Frigidaire Refrigerators
Refrigerator does not freeze enough
Lets have a look at rear wall of freezer, is there frost building up? Usually in top freezers the cold air settles to bottom and you don't notice fresh food section until about a day. If frost is building open fresh food sections door and in control panel=> CLICK HERE see item 257 in photo? That is WR9X565 or 311082 Defrost Timer Just below that is the control panel cover and you should have a small plastic plug covering a hole just below the defrost timer. Pry plastic plug out and using a flathead screwdriver turn the defrost timer clockwise slowly. Once you hear the compressor and fans stop stop turning timer and about a minute later you should hear some crackling noise coming from freezer. Allow to stay like that for up to 30 minutes and timer should come out of defrost and compressor and fans should start again on their own. If this action caused defrost then replace the defrost timer. If that does not seem to cause defrost the we need to go to step two, unplug and place items in a cooler or alternate refrigerator and use a hair dryer to assist in melting the ice behind rear panel. Remove rear panel in back of freezer and see => Freezer Components item's 621 and WR51X10038 or 880036 Defrost Heater Assembly
You will need to remove rear panel and work with refrigerator unplugged from power. On this=> Page watch how to test your defrost element just beside a photo of the timer. Most times I replace the defrost thermostat while inside freezer wall but I will let you try this first and please respond and rate, Thanks, Sea Breeze
Feb 13, 2011 | GE GTS22KBP Top Freezer Refrigerator
Mtb1953he fridge not cooling before it stopped fridge was making loud popping noise, i unplugged it then plugged it back in a day later to unthaw and fridge worked for 2 weeks now not working again. there...
It sounds like your defrost circuit is having a problem. Once frost builds up on the coil in the freezer compartment, air can no longer be pulled though the fins and circulated into the fresh food compartment. You notice things start to warm up. Eventually, the freezer suffers from the same lack of circulation and contents begin to soften and melt.
The defrost circuit consists of 4 main parts. They are: 1) defrost heater, 2) defrost terminator or sensor in series with the heater, 3) defrost timer and 4) wiring between the previous 3 parts.
The defrost heater is found in the compartment that houses the coiling coil. The defrost terminator or sensor is clipped or otherwise secured to be kept in physical contact with the cooling coil itself. The defrost timer may be located anywhere the manufacturer decides - a popular spot is in the toe space on the bottom of the fridge. The wiring, well, that is between all the parts. Chances are the wiring is fine - as would be the connectors to the individual components.
The defrost timer runs about 8 hours. About 20 - 30 minutes in that 8 hour period the defrost switch operates. This consists of switching power away from the compressor (so it shuts off) and to the defrost heater and defrost terminator. The heater is just a relatively small value heater that warms the compartment to melt any frost or ice from the cooling coil fins. It will be powered for up to 20 - 30 minutes by the timer or less - if the defrost terminator senses a rising temperature on the coil. This means that the heater will be on for either 20 - 30 minute OR until the defrost terminator gets warm enough.
If the timer is stuck - and never moves to the 20 - 30 defrost cycle, the frost on the coil will never melt away. If the timer does work, but the heating element has failed, the frost will never melt away. If the defrost terminator has failed open (preventing the power from getting to the heater), the will not work to melt the frost off the coil. If there is a loose, missing or damaged connection between the wiring harness and these components, it won't run as expected either.
Make sure there is continuity through the heater. When cold (below freezing) the terminator should also have continuity. Many are designed to open around 50 degrees F - so if you warm it up, you should see the continuity go away. The timer needs power to run, and will send power to either the compressor or defrost heater - never both at the same time. Check with power disconnected. Use care checking live circuits - and only work live circuits when you need to check for presence of power - otherwise, unplug!
I hope this helps. Please rate this reply - thanks!
Jan 05, 2011 | Maytag MTB1953HE Top Freezer Refrigerator
Food defrosted in top of upright freezer
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost thermostat, heaters, or trimmer
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up
Hope this helpout and Good luck
Jul 28, 2010 | LG LRTP1231W Top Freezer Refrigerator
Refer not cold and freezer frozen in the back but not keeping things frozen in the front. I have shifted the controls from high to low with no apparent change. This is a month long endevor. The fan in the...
Without the specific refrigerator model, it's difficult to say but generally...
  1. If the coils inside the freezer are frozen solid with ice, the air can't flow.
    Also, the air needs to flow from the freezer to the refrigerator, but can't because of the ice.
    Defrost the freezer completely, if it freezes up again, check #2 or #3.
  2. The refrigerator control module or timer may be bad, and isn't telling the freezer to defrost at the regular interval.
    The control module/timer will have to be replaced.
  3. The heater wire in the freezer may be burned out, and would have to be replaced.
A control module could be $35-$100, around $30 for a heater wire, plus labor.
I'm not an appliance repair technician, these are only estimates from previous experiences.
Best of luck,
-Greg-
Sep 13, 2009 | Refrigerators
Freezer compartment temperature at 30-32 degrees F
he is probably right , no frost and the machine is running like normal?
Jun 23, 2009 | Frigidaire FRT21H8 Top Freezer...
In addition to the popping noise/coils are froze with orignal
turns out the coils were not defrosting or at best working intermittently. I defrosted the coils and ordered a defrost timer the old timer continued to pop from intermittently.I replaced the defrost timer
and it quit popping and noew the freezer works fine temps range between 9 degrees F and
14 degrees f.
Jan 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Hotpoint FAZ50 Frost Free Freezer
If this is a frost free unit as I received it posted you may have a problem in that it is not frost free. The cooling coil may be frozen over stopping air circulation. There would be a defrost timer located somewhere in back. Located the clutch head screw and turn it clockwise SLOWLY until you hear one audible click. That should put the system into the defrost mode. Wait about 30 minutes in which time the system should return to the cooling mode (usually 18-22 minutes). If it does not restart the compressor after that time turn the clutch head screw clockwise again and it should restart. If you had to turn the screw the second time it would indicate a bad defrost timer. In this case replace the timer.
Jun 14, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Kenmore side by side 596.57582790
you would have to remove the back lower panel of the freezer section to get a feel as to whats going on in there. behind the panel you will find an evaporator panel that should have consist ant frost pattern from top to bottom with no excessive clumps of ice.I'm assuming you don't otherwise your refrig would be working ok..
either theres only the top 1 or 2 coils actually have ice on them, and the rest of the coil is bright shiny aluminum. or there is an excessive amount of ice built up so far that you dont even see an evap coil.
if the first is true and threre little frost then that points to a sealed system/ low freon issue. and call a servicer. you should have a full 5 yr warr. for sucha problem
if its the second issue hen theres a defrost problem and youll need to replace either the defrost heater, defrost thermstat( most likely),or the defrost board/timer
Mar 24, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
