Question about Carrier 52PQ307 Wall/Window Air Conditioner
Gas has leaked after filling in 2 months - Carrier 52PQ307 Wall/Window Air Conditioner
  • Carrier Master
  • 17,130 Answers
The leak has to be tested with a pressure test. use the air compressor to load and test for leakj. Only after the leak is identified should gas be filled into the system.
It willbe better to take help in this regards, the possible areas of leak can be the evapurater coils or the condenser side.
confirm and replace if the components are looking bad to leak further as time goes on.
Posted on Aug 29, 2010
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
What services does Kia Sportage 2008 with 90000 need?
Here is recommended maintenance up to 10 1/2 yrs. If you follow through list, you should be able to tell by elimination what you may need. Here is the link - also list pasted below, here:
http://www.kia-forums.com/2g-2006-2010-rio-rio5/35574-maintenance-schedule.html
SUGGESTED Maintenance Schedule:
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
Jul 16, 2014 | Kia Sportage Cars & Trucks
Gas Tank Leak when Filling / Check Engine Light due to Vapor Leak" I'm reading these gas tank filling issues on the 04 Avalanche, I've had them too. Now another issue; when you fill the truck and...
It may just be the fuel pump seal at the top of the tank. it has to be dropped for a definite diagnosis. It is rare but the tank seams occasionally crack too. Good luck.
Mar 17, 2017 | Chevrolet Avalanche Cars & Trucks
My air con gas is leaking i checked all connections but it takes about a month then there is no more gas left in car
You should have a leak detection dye added next re-fill so that the leak can be found!
Nov 07, 2009 | 2006 Ford Laser
I have a 94 priszm and have had to replace 3 gas tanks in the
If you have ANY DAMP SURFACE AT ALL on that Tank You DO Have a Leak and it Must be Found,
The Steal Fuel Lines around the tank Get Rusty and Leak You must ELIMINATE Any POSSIBLE Leak, as this can Turn into A Tragidy.
Jul 12, 2009 | 1992 Geo Prizm
Beverage air dd58 kegerator won't stay cold
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Jan 12, 2009 | Beverage-Air DD58 Beverage Cooler
Air-con problem
if you are filling gas, then you could have a small leak that lasts for 5 months.
normally we do find leaks at the evaporator coils. you can test your charge if you know how and if it is low, then you really have a leak, if the gas is empty, then you have a big leak.
to find the leak, trace the refrigerant lines from the compressor to the hoses to the condenser, filter dryer and evaporator.
look for oil stains. refrigerant leak leaves an oil stain where the leak is.
but it would be a big job if you have a leak in the evaporator plus you will need a qualified tech to service your vehicle.
what you can do for now is buy those small charge of refrigerant and if you can charge your system then charge it but be very careful in handling refrigerant. they can be fatal.
i hope i was able to give you insights on what you're problem is.
tnx 4 using fixya,
drcool
Sep 19, 2008 | 1995 Land Rover Range Rover
Carrier 52PQ307 Wall/Window Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
