Question about Maytag Neptune MAH5500B Front Load Washer
How do I get rid of the mold on the Front Loading Neptune Washer or Can I get it replaced?
    Scholar:
  • 91 Answers
Hi dear.Run the machine empty on hottest wash cycle & add some bleach while it's filling with hot water.(It can produce some foam when it's runing,it's normal)That should solve the problem.I hope that helps.Thanks.
Posted on Aug 29, 2010
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    The boot keeps getting moldy..yes, I ALWAYS leave the door open..even dry the folds with a towel. Its only a couple of years old! I have looked at other people's front loading washers..and noticed their...
    In order for you to get rid of the mold, you have to get rid of it. Wash your boot seal with vinigar followed by bleach and antibiotic soap. Make sure to rinse well before loading any clothes afterwards. It would not hurt to run vinigar through your wash cycle followed by bleach either. You have to kill the mold or it will keep coming back and soap skum is a breeding ground for mold.
    Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
    Clean with bleach solution and a Mr Clean Magic eraser.
    leave the door open to dry out the machine from now on.
    Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    Mold on rubber gasket on Maytag Neptune washer -- how do I get rid of it?
    you can not the door boot has to be replaced there is a black commercial one available although unsightly it will not cause any harm
    Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Black mold
    YES GETTING RID IF THE MOLD WILL HELP YOUR PROBLEMS BUT YOU WILL HAVE TO GET RID OF ALL THE MOLD AND ALSO CONSULT YOUR DOCTOR FOR A CHECK UP SOME MOLD SPORES CAN CAUSE SERIOUS DAMAGE
    Jan 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune Frontload....8 yrs old
    hi there,
    check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
    Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag front loader washing machine. Mould
    How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
    Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
    Maytag neptune
    When the door lock fails, there is a part on the electronic control board that fails (resistor burns up). Both will have to be replaced.
    Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
