Question about Kenmore 67082 Electric Dryer
Kenmore Dyer 65662
It will not start can hear timer.
    Genius:
  • 1,073 Answers
Check the thermal fuse on the blower housing, remove the back panel and you will see a white fuse with blue wires connected to it it is to the left of the vent tube of the dryer if it shows no contunity then the fuse is bad and needs to be replaced
Posted on May 07, 2008
I have a kenmore dyer model #10070602990, the dryer spins, but it does not heat up. what could be the cause?
thermal fuse, heating element, timer, or thermostat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Here is another website that is helpful:
http://www.applianceaid.com/general.html#timers
Feb 16, 2011 | Kenmore Dryers
Dyer heats up for about 1 minute then, no more heat.
Check the timer , the unit is shutting off when the timer is malfunctioning. If so replace the timer after trying to bypass to confirm that the gas supply is not cut off.
Aug 26, 2010 | Kenmore 74642 Gas Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
May 23, 2009 | Kenmore Dryers
Frigidaire Model FSE446RHS0 Dryer won't start.
its sound like the belt could have broken off or overheated normally when a belt breaks the machine no longer runs except for the timer noise you hear remove clotche from dyer turn the drum manually if it turns freely by hand that meens your belt is broken thanks from gilles
Mar 15, 2009 | Dryers
Dryer will not turn on
your motor switch is bad you need to replace the mmotor
Mar 02, 2009 | Kenmore 62602 Electric Dryer
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
No heat,,timer not advancing
Check with a multi-meter for power on THE heating element's tags (115/220V). If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Kenmore 67082 Electric Dryer Logo
124 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
