Question about Jazz Cameras
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it display's memory full, but the card is new and doesn't have anything saved on it. Can you please tell me what i did wrong, and how to format the card so i can use the camcorder. Thanks For Your Time Dean
  • 12,061 Answers
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Posted on Aug 29, 2010
Camera keeps saying memory full but have inserted new sdhc card
The S1030 works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
Can not format new memory card for samsung camera es27 .itsays on camera screen card error and camera will not respond
Could be the camera does not support the card. Your card specs: SD Card (up to 2GB guaranteed) SDHC (up to 8GB guaranteed. Try a card 8GB or less.
Jan 30, 2011 | Samsung Cameras
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
Have a SDHC 8gb Kodak card that won't format in Z1285
It's suggested that you use any SD Memory Card formatting Software to format the SD memory card. You can download any such Software from the address given below:
https://eww.pavc.panasonic.co.jp/support/jp/sd/sdfv2003.exe
Download the software from the above link and install in your computer and then format the memory card using it. After formatting the memory card, insert it in your Camera and use it normally.
Jun 23, 2010 | Kodak EASYSHARE Z1285 Digital Camera
WORKING CAMERA WONT TAKE MEMORY CARD
It's possible the camera won't take an sdhc card. Or maybe you just need to move the slide switch on the side of the card to unlocked or that you need to format the card in the camera.
Dec 26, 2009 | Cameras
My Sanyo hd1010 camera repeats format sdhc card on start up
its a fult with in the camcorder program chips only thing you can do is get it repaired or buy a new camcorder witch may work out cheeper
Oct 27, 2009 | Video Cameras
I only get 2minutes of video time after adding a 8GB SDHC card
There is small button on the card which needs to be unlocked so that the card is ready for recording. Also make sure you have changed the media from internal memory to Card in the settings section.
Thanks
Jan 25, 2009 | Cameras
I have the SD-1. It stops recording on my 8gb after only 43 min
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
Screen displaying "out of memory"
OK, FIRST OFF THE CARD YOU BOUGHT, IS IT COMPATIBLE WITH YOUR CAMERA? IT'S NOT AN SDHC, IS IT? ALSO, DID YOU FORMAT THE CARD? THESE ARE POSSIBLE REASONS YOUR CAMERA IS NOT RECOGNIZING THE 8GB MEMORY. IF YOU FORMATTED IT ON YOUR COMPUTER IT PROBABLY WON'T WORK IN YOUR CAMERA. YOU NEED TO FORMAT IT IN YOUR CAMERA TO HAVE IT BE RECOGNIZED. DOES YOUR CAMERA WORK WITH THE OLD CARD AND NOT SHOW THE ERROR? ARE YOU SURE YOU HAVE YOUR CAMERA SET TO USE THE SD CARD AND NOT INTERNAL MEMORY? CHECK THROUGH YOUR MENU ITEMS FOR CHOICES. TRY THESE FIRST AND IF YOU STILL NEED HELP, REPLY TO: ARCLIGHT1217. IF THIS IS HELPFUL, PLEASE RATE, THANKS!
Nov 30, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Cameras Logo
140 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Prashant Hattangadi
Level 1 Expert
Are you a Jazz Camera Expert? Answer questions, earn points and help others
