Recently I reformatted the hard drive in my Korg D1600 MKII. Choosing "format all", I did not realize it would erased ALL my songs! I had the "quick" highlighted thinking I was just cleaning up unused/erased tracks. Is there any way, any way at all I can retrieve them? Any help would be greatly appreciated!!! Marc
SOURCE: Format Hard Drive Error
here's what i did to solve the 'read access error': I mounted new batteries and tried to boot several times.... then i charged the batteries again for half an hour mounted inside archos. Started and shaking the archos a little while booting up and it could suddenly read harddisk again. Working! :-)
Posted on Aug 19, 2007
trintek
  • 111 Answers
SOURCE: 2 probs
Press the MENU and turn it on, as soon as the word RIO shows on the screen release the power button but do not release the MENU button until it says upgrading
Plug the USB cord to it and install Rio Forge Firmware_120
Turn the mp3 off then on normally
Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
hope this helps,
trin
Posted on Nov 19, 2007
SOURCE: Incorrect Format Please Reformat the Player
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Posted on May 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: incorrect format
The songs that you loaded onto the player are not in the correct format - iTunes, DRM-encrypt. WMA are not allowed, for instance. Convert everything to mp3 format. It is asking you to reformat the player because it wants you to delete the wrong-formatted songs off the player. I would check your user manual to find the best way to reformat.
In general, though, there are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
AllenTech08
  • 54 Answers
SOURCE: Bad Track
You need to run a check disk on your Sansa to fix this.
First make sure you back everything up from your player if you haven't already done so.
Now, make sure your player is in MSC mode. (to do this, go to system--USB mode and choose MSC on the Sansa), and connect your player to your PC.
Next, go to My Computer on your desktop to see what driver letter your player is, then go to Start on your PC and choose run (if this is Windows XP and type "cmd" in the run box and hit enter on your keyboard, if you run Vista you will type in the word "cmd" in the Start Search field).
Once the command prompt (the black and white window opens) type the following chkdsk x:/f (I placed an "x" there as an example but the drive letter of your Sansa may be different, make sure the drive letter after the "/" symbol is correct for your player) and hit enter on your keyboard, and let it run.
This will fix the bad sectors of your Sansa that are causing this.
If this continues, you will need to format your player (hence the backup) and rerun the above then upgrade your firmware, but before we do that, the first option I gave normally fixes your issue.
Posted on Mar 28, 2009
It claims to be full. How do I empty it and start over?
It depends on your operating system but is similar for most windows versions.
For windows 7/vista
Click Start Click computer right click the flash drive and click format check quick format and then click start
Note: this will erase everything on the drive.
Mar 05, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
My freestyle player says format error how to fix?? it was working fine and then this error.
Hello there,
Q.: My player is having a DRM error / Format Error / Empty Disk Error
what do I do?
A: For all 3 errors, the first step is to attempt to reset the player, this can be accomplished by pressing the play and menu
buttons down together for approximately five seconds. If reset does nothing, make sure all the songs are .mp3s, if all songs
are .mp3s, attempt to format and re-sync the player.
if you need it
How do I convert my iTunes into MP3 format?
A: See Music Conversion Instruction Document: Transferring and Playing Music on Freestyle Audio mp3 players with
iTunes.
if you need to format the player here is how for MAC and windows.
Q.: What's Reformatting, How do I format my Player?
A: Reformatting your player basically wipes you player clean and deletes all songs, leaving you with a blank slate. Like
most removable drives you can reformat your player with no worries of damage to the unit. When reformatting on a Mac
make sure you choose the MS-DOS format style.
(CAUTION: FORMATTING WILL ERASE EVERTHING ON THE DRIVE)
PC (Windows NT, 9x, XP and Vista):
1. Plug in the Mp3 Player.
2. Put the Player in removable drive mode. Under "My Computer" you should
see the player as a removable drive.
3. Right click on the "removable drive" and a Drop down menu should appear.
4. In the menu select the option "format..."
5. Make sure that "FAT" is selected as the file system and that Allocation
Unit size is set to "Default Allocation Unit Size"
6. Now click format and wait, after it says format complete, you're done.
MAC OS 9 (and Earlier):
1. Plug the player in.
2. Put the player in removable drive mode.
3. Single-click the disk's icon on your desktop to format.
4. Pull down the "Special" menu from the top of the screen and select "Erase
Disk..."
5. Enter whatever name you want in the "Name:" field in the window that pops
up. If the disk is a hard drive, select "Mac OS Extended" from the
"Format:" pull down. If the disk is not a hard drive (such as a Zip Disk
or other removable media), select "MS-DOS or MAC OS Standard" for the
format.
6. Press "Erase." The drive will be formatted and ready to use.
MAC OS X (and later):
1. Start your computer and plug in the player in the USB port after the Mac
OS has completed loading.
3. An icon for a removable drive should appear for the flash drive on the
desktop.
4. From the Dock, open "Disk Utility".
5. Click "Erase" from the top selector (next to "First Aid")
6. Choose "MS DOS File System (FAT16)"
7. Click the "Erase" button
8. Perform the instructions given on the screen and finish the formatting.
if you need any help with a Step let me know and i hope this information was helpful don't forget to Rate .
Jan 27, 2011 | Freestyle Audio MP3 Player
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Save/load problem on ps3
Nov 13, 2009 | Sony PlayStation 3 40GB System
Wont save over 1 song and always turns off
Try asking here:http://www.korguksupport.co.uk/page.cfm?pageid=370. Hope this helps.
Aug 23, 2009 | Korg Mr1 Digital Mobile Recorder
My dp01wth cd recorder says no more disc space when trying to rec
You may wish to first verify that you have indeed erased those songs (by choosing 'erase' in the 'song' menu - see page 18 in your manual) and not simply cleared out the fat partition. You cannot erase songs on the DP-01 from your computer, you can only do this in the DP-01 menus.
If you erase all the songs from a disk partitian the DP-01 is supposed to automatically create a new blank song. So the partition or the hard disk could have become corrupt because you say you aren't seeing any song there.
If you haven't already, you could try selecting another partition to be the active one (press 'menu', select the 'disk' menu, choose 'partition' and press the > arrow key. Move the arrow symbol to the partition you want to make active and press enter - see page 36 in the manual) to see if another partition works any better.
If the newly selected partition does work, but the original one didn't you might have to reformat the old partition. Re-select it as above, and follow the instructions to reformat a partition on page 37 in the manual).
If the newly selected partition doesn't work either, then your hard disk might be corrupted. At this point you could try a disk reformat (page 36 of the manual) during which you'll have to set the partition sizes. The disk format instrcution of page 36 will walk you through that too,
Hopefully it's just something simple and you won't have to get into formatting anything.
Good luck with it.
bd.
Jan 14, 2009 | Tascam DP01 All-In-One Recording Package...
My insignia
Try reformatting the unit using your PC as a FAT formatting. Don't use "quick format" so you can completely erase any glitchy memory points.
Also, press and hold the Reset button (little hole on the bottom right of the player) to reset the software.
Jul 20, 2008 | Insignia NS-DV2G MP3 Player
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
-Tha Mp3 Doctor
Apr 24, 2008 | iLO MP3 Player
Reformatting.
hi there,
you can Format your drive on a Windows machine as "FAT32" and it will be usable both under Mac OS X and Windows. the only thing to make note of is there are some limitations on the FAT32 format, like the 4GB filesize limit and certain naming restrictions.
You can reformat your drive by opening Disk Utility and then reformatting it using that application. in Mac OS X
- In Disk Utility, select the disk.
- Click Erase.
- Choose format from the Volume Format pop-up menu
(select the windows based format).
- Type a name for the disk or volume.
- Click Erase.
- You can use the drive on both the mac and a PC by choosing MS-DOS from the Disk Utility application when you're about to reformat.
Apr 13, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Incorrect format
-Tha Mp3 Doctor
Mar 03, 2008 | AIGO F008 MP3 Player
196 people viewed this question
 Grubhead
Grubhead
