Question about Sony Handycam DCR-HC14E Mini DV Digital Camcorder
C:31:23 I have tried to off the camera, took the battery and also the mini cassette, it is still the same problem. Pls help
  • Anonymous May 29, 2008
    I have the same problem, have been unable to clear the error.
    Kevcon9497@comcast.net
  • 10,594 Answers
In DCR-HC14E model, error C:31:23 means Supply Reel signal in not present. Its mechanical problem and needs qualified technician to resolve it.
Posted on May 30, 2008
No signal, only blue lcd-monitor, when playing my footage, yesterday it was ok. also trouble with recording
Did you try resetting the camera by turning it off, taking out the battery and removing any other source of power? Try this first to hard reset the camera.
Does the optical viewfinder function or is it also blue?
Hopefully hard resetting will solve your problem but if not then there may be an electronics fault in your camera.
Jun 24, 2008 | Sony Handycam DCR-TRV900E Mini DV Digital...
I can't eject a mini cassette on my canon dv960,pls tell me what to do?
Hi
Try to turn off your device and remove the battery for about a minute. Reinstall battery and check for physical damages on the mini cassette door and try ejecting the cassette
Thanks for using Fixya!
Hope this helps
Sep 17, 2010 | Canon MV960 Mini DV Digital Camcorder
Unable to load cassette.. wen i try to load, the cassette does not load and is ejected out with a few beeps.. pls advice on this..
my opinion ,that it look like a defective cass in switch
or a mechanism alignement defective ,because the servo control chips do not receive the mechanism pulse
information to start the loading cassette process....
it something there....
Feb 25, 2010 | Canon ZR600 Mini DV Digital Camcorder
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Mar 28, 2009 | Canon ZR300 Mini DV Digital Camcorder
Sony camcorder
pls clean the head of camera using DV tape cleaner cassette and see if it helps pls do rate me if it helps to fix ur problem
Feb 25, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Card error cassette error
A common fault, take it back to the shop!
Dec 25, 2007 | Canon Elura 70 Mini DV Digital Camcorder
SONY DCR-TRV285E
Hi lskumar!I have also got SONY DCR-TRV285E and it gives the same problem as yours. It took me long 3 months to get around the problem. I surfed a lot and found that many people are facing the same problem with sony cameras.
Now the fix is - When your camera gives "Reinsert the cassette" message", take a pen / pencil like object and push the reset switch on the camera. Its just below the volume +- buttons. The camera would restart. See if this solves your problem. If it doesn't then switch off the camera and apply Indian style of repair - Give 1-2 slaps on the cassette side but don't hit too hard. Then switch on and reset again. Repeat 2-3 times if necessary.
This is weird but it works for me. I got this solution from some forum on internet. Hope it works for you too!!! Remember, this is only a temporary solution. The problem keeps on arising every now and then. The SONY ppl don't have any cure for this. They don't know why it happens.
One more thing. Buy a good head cleaning cassette. This would give new life to your camera-head.
Have a nice day! Do tell me if it works..
Sep 01, 2007 | JVC GR-DF450 Mini DV Digital Camcorder
Sony Handycam DCR-HC14E Mini DV Digital Camcorder Logo
361 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
