Question about Maytag Neptune FAV6800AW Top Load Washer
This is the second time...there is sand in the washing machine after a wash (and sand in the sheets)
  • Maytag Master
  • 17,130 Answers
There is no other way that sand could have come in unless through the inlet water line or sand previously lodged into the tub into the clothing. To check this out remove inlet line and check for damage in filter.If not check inside your tub for traces of sand.Remove drain hose/drain valve and clean external tub to wash away all dirt using a jet wash.
hope this helps
Posted on Aug 29, 2010
When washing my sheets I get black marks on them. I only wash one bed load at a time and I do not use fabric softener in my machine. This doesn't happen every time I wash the sheets, but often enough that...
It sounds like there is a build up of soap powder and it just needs a good clean.Try cleaning the agitator and bowl.
Remove the fabric softener cup from the machine undo the wing nut and take the agitator out and give it a good clean underneath and also while the agitator is out give the bowl a clean down. Then once you have done that and placed the machine back together run the machine through a high water level hot wash with two cups of vinegar added (with no clothing in the machine).
Jul 22, 2017 | Fisher and Paykel GWL11 Top Load Washer
My whirlpool front load washer wfw9500tc01 washed a load of sheets and then at rinse cycle it put up "sud" and a few seconds later it had a F21 code come up and now it acts like the pump is working but it...
Ok here is whats happening. 14b0f4a.jpgTheir is too much soap in the machine. The machine only uses a gallon or 2 at a time.01f5935.jpg You go adding in too much soap and it is gonna detect suds.aa3f677.jpg F21 Long drain. Possible cause: Clogged filter, clogged/failed pump, too much dang soap. c5d1358.jpg
Jun 17, 2010 | Whirlpool WFW9500TC Front Load Stacked...
LG Washing machine leaks from the bottom when large items such as flannel sheets are placed in the machine. It does not leak at any other time but I had water all over the floor twice when I tried to wash...
Water may be working its way up and over the inner wash tub with the larger items. Ensure that you are not overloadinig the washer. You may want to contact an appliance service company.
Feb 22, 2010 | LG Washing Machines
Washing machine u/l all the time ?
whirlpool F1 code - Appliance Repair Forum i would call the factory because there is a recall on your washer,they're having problems with the control board,also in the console there is a tech sheet that has all the error codes on it,put it back,without that paper if you call someone out in the future they will need the tech sheet to find your problem
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Seems to be clogged and will not drain a bath mat's bottom surrface completely crumbled into a sand like mixture
Your strainer's likely plugged with the "sand". Locate your dtrainer, situated between the drum and pump, and connected to the drum with a rubber hose. Clean and reinstall it. Get all of the sand out, and remove any that you can see laying in the pump cavity, etc. Run an empty load to flush the machine. This may have to also be done a second time if there is a lot of residue.
--W/D--
Aug 18, 2009 | Fisher and Paykel IWL12 Top Load Washer
A few seconds into a wash cycle the letters F H flash and beep and the cycle won't continue. what does this mean??
fh means fill hose make sure that water is comeing out of each hose by detaching from washer and filling a bucket. does water come out of hot and cold? check and make sure your fill valve washers are not clogged with sand. if neither of these things fix it I believe you have a bad flow meter. take the kick panel off by removing the 3 torque screws look to the right side you will see the tech sheet. read the fh error code. let me know how it goes. Do you have flood stop hoses if so get ride of them right away they cause a ton of problems with all washers.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sand continues to be present in the washer
check your in bound lines if you have a filter in your house it may be leaching sand into your water supply or if you are on a well it also my be leaching sand check your inbound water by filling up a bucket with water using your supply lines
1 bucket for hot 1 bucket for cold
this might help locate the contaminatin in your system sand will tend to colect at the lowest point in a water system
Feb 16, 2009 | Whirlpool LSN1000LW Top Load Washer
Grey lint all over sheets and dark color clothes
less soap and shorter wash time or wash on perm press cycle but this is a common problem.
Jan 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune FAV6800AW Top Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
