Question about HP OfficeJet J4580 All-In-One Laser Printer
I cant add my printer to my mini 311 note pad
  • HP Master
  • 17,130 Answers
First of all install the software after removing the earlier version if any on the note pad. Then connect the printer to the PC to detect and install.
the printer must work now unless the OS in the mini is not accepting the software to help it to be compatible.
Posted on Aug 29, 2010
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure Solution : Power the Machine Off and On CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
  1. Press the power switch to the [O] (off) position.
    NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
  2. Wait 60 seconds, and then press the power switch to the ['] (on) position.
Jun 26, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Can I update the operating system of hp mini 311 from Windows Xp to Windows 7?
Update? Upgrade yes.
Windows xp cannot Update windows 7
Upgrade in this particular means Get new operating system,which means it will wipe out your C drive(XP) to a new fresh operating system windows 7.
NOTE: all Xp files and folder might lost on drive C.
akee_akee@live.com
Aug 17, 2011 | HP Mini 1010NR Notebook
C5280 printed from note pad but not anything else
Cant go ahead with this because noting is mentioned
Let me know the OS
let me know the OS with SP
what happens when we give print command from other application
Oct 10, 2009 | HP Office Equipment & Supplies
Universal rca 311 remote works on the sanyo tv but i cant get the input button to work so i cant swith the video source to watch dvd?
The keypad has a insert under it with the back side has what appears to be a group of black buttons attached to it. Remove battery and open your remote. Clean this buttons with clean cloth and alcohol. Also clean the circuit pad with which these buttons come into contact. This should fix your problem
Jan 20, 2009 | RCA RCR311B Remote Control
HP OfficeJet J4580 All-In-One Laser Printer Logo
Seeker5211
Seeker5211
