Question about Actiontec (GT701) Modem
Actiontech GT701 modem
I can't seem to find my intallation disk and the modem will not hook to the internet.
My power light is on but the internet light flashes green.
  • 2 more comments
  • mzminie Aug 29, 2008
    how to surf into modems gui
  • Anonymous Oct 02, 2008
    I am having the problem where my internet light isn't actually even on, I can't get a wireless signal, and my hard wired computer can't pick anything up either
  • Davewren1 Oct 02, 2008
    anything up either
  • Anonymous Mar 10, 2009
    does a action tek gt701 work with the linksys gaming adapter
4 Suggested Answers
Verizon
  • 14 Answers
SOURCE: Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Posted on Jul 11, 2007
Geekman
  • 32281 Answers
SOURCE: I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Posted on Oct 31, 2009
  • 149 Answers
SOURCE: Yesterday had Cable Internet hooked
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Posted on Jan 04, 2011
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
Apr 08, 2010 | Actiontec GT701WG Router (actiongt701wg)
Loosing internet
Call Verizon and have them check the phone line. it sounds like a problem only they can fix.
May 30, 2009 | Actiontec (GT701) Modem
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
May 07, 2009 | Actiontec (GT701) Modem
Actiontec gt701
Did you Unplug the Modem from Your Electrical Outlet, AND Unplug the Telephone Line coming in too, for 5 minutes?? Give "it" a chance to Completely Re-set/Reboot..I have a GT701 DSL Modem, that's what I did, and it worked fine. "IF" that doesn't work I would go to "Support" at either Action-Tech or Your DSL/IP Provider. Hope this Helps you.
Feb 27, 2009 | Actiontec (GT701) Modem
Red internet light stays on
the following link provides some very streightforward advise;
http://www.qwest.com/internethelp/modems/gt701/pdf/13566_GT701_ServiceStatus_031906msl.pdf
check the following in order
1 check that all of the cables are securely plugged in, if you find any loose plug them back in, you may need to powercycle the router afterwards though if the router is subsquently plugged into another unit down the chain power off both units turn them back on turning on the actiontec last.
2 if your ISP requires logon details to be included in your router, double check by viewing your router settings renter them if you are unsure.
3 lastly, have you paid your ISP bill?
Nov 05, 2008 | Actiontec GT701WG Router (actiongt701wg)
Actiontec Modem Won't Work!
take a wire and carefully touch it to the two attachment points of the copper ring on the left side while it is plugged in. I first froze my system for 15 min then thawed out and touched the wire as instructed and all works fine.
To open the box remove the clear soft contacts on the bottom, should be four. Using a small philips remove them and pull the box in two. Then fix according.
Hope this helps
Aug 27, 2008 | Actiontec (GT701) Modem
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
Actiontec GT701R modem
what you running it from(computerwise)..sounds like you may have a driver/interface issue with computer.
got backup?
Feb 19, 2008 | Actiontec (GT701) Modem
Jul 07, 2007 | Actiontec (GT701) Modem
Actiontec (GT701) Modem Logo
440 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
