Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Tv shuts off sporadically, and now won't recieve any video signal
My tv started going black sporadically about a week ago. i thnk the first time I still had audio. if we shut the tv off and turned it back on again, it would be fine. some days it barely did it, others every few minutes. Now it's blue, and says that the video signals are wrong... thought it was just working a few minutes before. has anyone had this happen? thank you!!!!!!!!
  • Pactus1 May 17, 2008
    Same problem as above. At first I thought it was the cable box, but after a new one was installed, it continued to do it. No, all I get is a blue screen even on the DVD setting.
    Same a
  • Mitsubishi Master
  • 8,617 Answers
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
Posted on May 08, 2008
Hi I have a Aldi bauhn LCD tv and its not recieving the remote signal. I have checked through a camera for the remote control light signal and it works with every button. So that leaves the reciever
Will cost more to fix then a new unit , replace it and try to buy a extended warranty with the new one, most times you can get 3 years after the original warranty runs out.
Apr 04, 2017 | Televison & Video
I bought a 19" element
Is a tv power glitch,shutdown,start again,tv have no problems,wright?Not a problems,if only happen one?If it happen many times,tv have power supply board problems,take ur tv warrenty repair or return ur tv,where u bought it,get a new tv replacment.
Nov 23, 2010 | Element ELC-HS321 32 in. LCD TV
Red Vertical bars cover the right 1/4 of the screen. They starting appearing sporadically several weeks ago and would go away, now they stay on the screen, regardless of video input ..
Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the TV requires service.
Jul 25, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Jan 13, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
