Question about LG 42PX3RV 42 in. EDTV-Ready Plasma Television
Loud pop noise made lose of picture but sound remains are able to change channels everything still work only there's are black screen
  • LG Master
  • 11,800 Answers
The loud pop was generated by the explosion of one of the capacitors from the power source. Open the back of the tv and replace all capacitors from the power source - if one has failed so badly  then the others can't be far behind. After that check what other components the failed capacitor might have damaged: rectifiers, coils and the IC's from the Y and Z -sus board.
Basic knowledge of electronics is required, if you don't have it then call a certified repairman.
Posted on Aug 29, 2010
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
P50 sound ok picture went dark but not out all the way. Made a loud noise when it happened
did you ever get a answer?
i also have a p50hdtv with a black flickering screen
but no pop and sound is still working.
May 10, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
LG plasma tv made loud popping noise
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
Apr 23, 2009 | LG 50PX5D 50 in. Plasma HDTV
Sounds like a jet taking off
the horizontal output transistor is busted or a protect diode,check the plyback maybe it has a leak
Oct 15, 2008 | Samsung HL-P6163W 61" TV
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Black Screen VERY loud noise
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Oct 14, 2007 | Samsung HLN5065W 50" Rear Projection...
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
LG 42PX3RV 42 in. EDTV-Ready Plasma Television Logo
103 people viewed this question
