Question about Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook
I have a new battery for ldell latitude d630 it doesn't charge. I ihave taken battery out then put it back in turned laptop on and battery light after about 30 seconds blinks orange.
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 29, 2010
Dell LATITUDE d630 Static noise
canna420bis
You may want to reinstall the audio driver into the system to see if that will resolve the issue. Another step to try is to plug the system directly into a wall outlet bypassing any power strips or surge protectors to see if that could be causing this to happen if is not already plugged.in.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2013 | Dell Latitude D630 PC Notebook
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
Hi have got a dell latitude d630 laptop and a emos battery buy cant seem to be able to pinpoint what type i need many thanks
Under back of the laptop, you will find the service tags.
Go to dell official site to check your laptop details:http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details
Also, if you need a replacement battery,those sites may helpful:9-cell dell LATITUDE D620 Battery http://www.battery-center.net/dell-latitude-d620-battery.html
6-cell dell d620 battery http://www.brand-new-battery.com/dell-latitude-d620.htm
Oct 30, 2011 | Dell Latitude D630 Notebook
My dell latitude d630 will power on when I push the button, but nothing happens. The screen illuminates a bit and that's it. What can be the problem?
what happens when you try to connect to an external monitor? you may have a bad back light power inverter. how old are your batteries? in some cases if the batter pack isn't holding a charge then it may put a load on the power supply.
if you connect an external monitor and it stays on then it is a bad back light inverter. if it does the same thing then you may have a power supply problem. i forgot to ask if the laptop has been dropped or fell off a table, chair, bed, or desk? how is the power plug that plugs into the laptop? you also may have bad power jack!
3 things that may be bad or defective:
1) power jack
2) inverter board (i'm thinking this your problem)
3) batteries or internal power supply
items 1 and 2 can be fixed, but if it is a battery(s) or bad internal power supply. replacement batteries are about $50 and up, replacement laptop mother board it may be cheaper to buy a new/used laptop. however, you would want to save your data on this laptop if you can or someone do it for you.
i have worked on Dell computers for 10 + years out of my own repair and custom shop.
oops almost forgot with the new hd tv's there is a "PC Input" on the back where you can connect your computer or laptop to!! so if the lcd screen doesn't work and you cannot afford a replacement back light inverter board($120) then spend $15 or less for a male plug to connect your laptop to your lcd hdtv .
but doing this you will loose portability unless replace the inverter board!
Aug 22, 2011 | Dell Latitude D630 Notebook
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Im 86 yrs old and just purchased a refurbished dell d630 from goodwill. i charged it all night, and no power. computer wont cut on but it did before the battery died completely. is it possible i have meybe...
The power cord should have a power brick it connects to, on this it should have a green light. If it's on then there is power if not then the fuse is probably gone or the adaptor has been damaged in the latter case send it back.
If the light is on then when you plug it into the power socket of the latitude it should light up a small led on the top right of the laptop. If this doesn't happen then the laptop is damaged and you should send it back.
Sep 17, 2010 | Dell Latitude D630 PC Notebook
My dell D630 won't power up and the light from the ac adapter turned off whenever I plug it on the dc socket of the laptop. I tried unplugging it and then replugging it back to the outlet the light from...
Please remove the Battery and try to turn ON the Computer and try connecting to any other known power outlet. if the same issue persists, then the service may be required
Jun 24, 2010 | Dell Latitude D630 Notebook
Latitude D630 PC Notebook: Im trying to remove BIOS admin password because I ...
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
May 17, 2010 | Dell Latitude D630 PC Notebook
Change Dell lattitude D630 battery
If you mean buy a new one I have taken the liberty of providing you with a link already set up for you on Ebay
Aug 27, 2009 | Dell Latitude D600 Notebook
Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook Logo
59 people viewed this question
Alun Cox
