Question about Epson Office Equipment & Supplies
Double flashing red lights? - Epson Office Equipment & Supplies
  • Epson Master
  • 17,130 Answers
Possible failure of the projection lamp. You must open and clen filters and make a final check. Remove power and Hold down standby sw to power on. If the fault repeats it is possible that the lamp is defective.
Posted on Aug 29, 2010
  • cpauley Jan 28, 2011
    projector lamp works fine with all other sources (computer). IT is only when using the document camera.
I got a radio from the wreckers, got the code but when I turn the key on, the screen stays blank and the red light next to the word disk is flashing, what does this mean and can I fix it?
pop a disc in see what you get
screen should power up
wonder if the wiring is incorrect
should have a power constant and a power ign ,earth
speakers pos & neg ... arial if fitted
who is the maker of the radio
Oct 18, 2016 | Cars & Trucks
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
How do I remove the double flash from Vivitar 8025?
on some cameras (like sony) there is a very fast double flash .. you see only one .. the first sets up the shot the second takes the picture ... its not likely that your vivitar has this feature so i am thinking that your "noticable" double flash is caused by "red eye reduction" being turned on .. on my vivitar (dc8600) the flash mode including red eye reduction is selected by the 4 way switch .. by pressing the right tilt you can cycle thru all the flash modes ... that includes no flash, forced flash, automatic flash and red eye reduction..maybe other modes as well .. the flash is in fully automatic mode when no sysbol appears on the screen .. thats probably where you want to be ... that will flash only once per shot and only when needed .. ..
Jul 25, 2009 | Cameras
Double Red Flashing Light
I just posted another solution on the main link. Basically hook up the unit to the ac adapter, reset the menu to get rid of the blinking red light, and then put a new tape in on camera mode. The unit was able to record again and also work in camera mode.
Jun 09, 2009 | Panasonic Palmcorder PV-DV53 Mini DV...
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
RED FLASHING LIGHT TV BLACK
does the television stay on ? these codes or flashing lights and designed to tell you about a problem that the internal computer had detected - a single flash then a double flash is a software upgrade notification -- call support at customer service and they will tell you exactly what the flash is related to then you can find the fix or repair with more information
Jan 25, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red eye
RED EYE is caused by the sudden flash from your camera and the eyes reflex reaction to the sudden light. So what the red eye reduction does is to double flash to counter the reaction. You can try adding an external light source to to your subject. in addition to the following procedures for your camera in the manual, the indicator location on page 64 Flash On Flash Off Red-eye reduction C REC modes on page 52, Snapshot; pg 64, have the flash fire automatically when required (Auto Flash) * Turn off the flash ... recording with flash, reducing the chance of red-eye in the image (Red- eye reduction) In this case, the flash fires automatically; Also, be aware of the following: The approximate effective range of the flash is shown below. Wide Angle Optical Zoom: Approximately 0.4 to 2.9 meters (1.3´ to 9.5´) (ISO Sensitivity: Auto) Telephoto Optical Zoom: Approximately 0.4 to 1.6 meters (1.3´ to 5.2´) (ISO Sensitivity: Auto) * Depends on zoom factor
Aug 22, 2007 | Casio Exilim EX-Z750 Digital Camera
566 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
