Unlock lock system - Washing Machines
  • 28 Answers
Depending on the make and model on the unit, the child lock is performed in many ways. Look on the control and you will find a child lock button or a combinatio hold for of buttons that will say x number of seconds.
Posted on Aug 29, 2010
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
I bought a honda civic sport 2005 got it resprayed and i built it up and now the alarm keeps going off the key fob doesnt work etheir the battery has been flat . does any body no how to reset the fob or...
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
IMMOBILIZER CAN ONLY BE SET BY DIAGNOSTIC EQUIPMENT
May 13, 2011 | 2005 Honda Civic
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
Mar 02, 2010 | 2002 Honda CR-V
REMOTE KEY LOCK DOES NOT WORK BATTERYS NEW BUT ALARM WILL NOT SHUT OFF WHEN FIRST START .HOW CAN I DISABLE ALARM
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Carry out the following within 1 minute: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
How
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed
Feb 09, 2010 | 2000 Volkswagen Beetle
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
How
Jan 25, 2010 | 2004 Honda Accord
How to recode remote to vahicle
Programming
When
How
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
