Question about LG Cell Phones
Insert sim card - LG Cell Phones
    President:
  • 1,118 Answers
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Posted on Aug 29, 2010
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Mar 22, 2013 | Panasonic Toughbook CF-H2ASFAZ1M 10.1" LED...
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 | Cell Phones
What do you do when a tmobile tap cell phone says sim card not inserted and there is one inserted but its not working
Hi,when a phone says insert Sim when there is Sim card, Means that either the Sim card is bad or the Sim tray where you insert Sim is bad.
First use the Sim card on another phone and see if it will work, if the Sim card works, that means the Sim card tray will need to be replaced.
Take care.
Aug 12, 2010 | Cell Phones
Ive inserted a vodafone sim card in sciphone, phone sayn insert sim. also why is there 2 sim card slots?
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
Dec 16, 2009 | Lands Phones
Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
Jul 27, 2009 | Nokia 6070 Cellular Phone
Insert sim
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
cheers.
May 04, 2009 | Sony Ericsson Walkman® W880i Cellular...
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Cell Phones Logo
137 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
