Question about Toro Garden
I have a toro lawn mower, model LV195EA. having touble with it all summer, run for a while then stopped, so clean gas. seemed to help, now I can not get it to start at all. changed spark plug
  • 3 more comments
  • James Jackson
    James Jackson Aug 29, 2010
    we are going to try it. but in researching on the internet, lot of prop have respored probems - posted is the question and answer to someone on the internet:
    have a Toro 22" Recycler Lawn Mower Model No. 20017 that will not start. I tested for a spark and did not get one. I then removed the shroud and noticed a green wire coming off the Solid State Ignition and going under the flywheel. When I disconnect this wire, I got a spark. The mower runs fine with the wire disconnected. I am now assuming the problem has
    something to do with the dead-man bar. The cable running from the dead man bar does seem loose, but I don't see a way to tighten it. Does anyone have any suggestions on how to fix the problem?
    I replaced the brake cable as jsouth suggested last night. I started it twice with no problems. I ran it for about 1 minute each time. I went to cut the grass this afternoon and it ran for about 30 seconds and then stopped as though I released the dead man bar. The only way I could get it to start was to disconnect the green wire coming off the Solid State Ignition again.
    The new cable is much tighter and does a much better job than the old one. But, apparently not good enough.
    Does anyone have any other suggestions?
  • James Jackson
    i posted my comments on the solution you sent. need more help
  • James Jackson
    al;ready done this -- no halep
  • James Jackson
    please direct me to way I can download a manual with parts to my toro lawn moweer Model lv195ea Please do it asap
  • James Jackson
    James Jackson Aug 30, 2010
    please tell us how to download a manual for this model. I asked for it before. PLease tell us how to down load. thank you
  • 3,740 Answers
Remove the float bowl on the carb and remove the debris from the float bowl. Also in the very bottom of the carb where the float bowl attach nut screws in there is a jet. Take some carb cleaner and shoot into the hole to remove any debris from the jet.
I note you say you changed the spark plug. Is the problem fuel or spark related? It appears to be a fuel issue.
Also if we have to go beyond this post and I will gladly do so to resolve your mower problem. (I have over 40 years of hands on and in shop experience.) I really need your engine model number vs the Mower model number after this. Toro uses 2 different engines on that model of mower.
Thanks for choosing FixYa.
Kelly
Posted on Aug 30, 2010
  • Kelly
    Kelly Aug 31, 2010
    Here is the Technicians Handbook for 3 to 10 hp L series engines:
    http://www.cpdonline.com/692509.pdf
    I have yet to get any notifications on this problem so I have to assume your working with another expert. I only see what you stated requesting the manual twice. I said before I really needed you ENGINE model number. (It was my error in not noticing that you were already using the engine model number. When I do send you the mower manual link all your going to find is parts for the mower body and NOT the engine. Just the way Toro works. Engine parts are by engine model number only. LV195EA is a 6.5 HP Tecumseh Engine.
    You can see the parts diagram by choosing engine parts diagram 1 or 2 here:
    http://www.partstree.com/parts/?lc=tecum...
    Thanks for choosing FixYa,
    Kelly
  • 2,973 Answers
Tazman,
As you say that the machine runs for a short while and then stops, it seems that the ignition coil is bad. It gets heated up and the machine stops. When cooled, it lets the machine run till it gets heated up again. Please replace it. It can not be repaired. Once gone is gone. Its cheaper to replace it. Keep the old spark plug for emergency use. Adjust its gap as much as the new plug's.
  • 580 Answers
Shut the gas off & remove the float bowl of the carb. Be careful not to displace the float seat & needle. Put a cup under the carb & open the fuel valve briefly & close. Clean the float bowl & replace the same way as taken out. Make sure the bowl sits properly on the gasket. Retighten the float bowl snugly. Do not over torque it. Now there is a fuel richner screw at the bottom of the float bowl. Using your fingers only tighten the screw till it bottoms then back it off 1 1/4 turns. Turn the gas on & start. If it idles rough, back the screw off another 1/4 turn till it evens out. Toro is one of the best machines on the market. Hope this helps you & good luck!
Posted on Aug 29, 2010
  • 17,130 Answers
First of all remove thespark plug and check the intensity of the spark . the spark plug gap must be about .5mm and shouldspark with good intensity.if you do not get a consistant spark check the contacts the connections to thecoil HT wires.Once you have confirmed of good firing crank up the engine to disperse over flow.Now replace plug ensure good supply of gas{please make sure that the fuel pressure is adequate}.the mower should work.
  • Donald DCruz
    Donald DCruz Aug 31, 2010
    the green wire could be coming from the oil pressure sensor switch and if the oil has not being changedthis can cut offf the ignition. so check this out. or keep it removed to start and confirm.
I have a 6.5 hp toro lawn recycle mover , that will start, but will not continue to run but a few seconds
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Mar 16, 2016 | Toro Power Lawn Mower
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and...
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Nov 06, 2012 | Toro Lawn Mower With Toro Power Tools
Will not start toro model143.026706
if it stopped running after hitting something with the blade check the key on the flywheel where it meets the crank
Jun 04, 2012 | Toro Power Lawn Mower
NEED VALVE GAP FOR A TECUMSEH 2 CYCLE MODEL LV195EA??
2 cycle motors don't have valves , so I guess I don't exactly know what you are asking would like to help you
Apr 16, 2011 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Model # 20331 Starts, but doesn't run
Mr. Fixit...excellent advisement...really appreciate it. It got my grass cut today. Big yard! Problem is, when I finished, now I have the same problem with it not running...what do you think: take the Toro to the junk yard or what? Thanks!
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
828 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
