Question about NordicTrack E4000 Treadmill
The incline ramp on my NordicTrack CX990 Elliptical trainer is stuck. The motor works but the drive screw only turns a little, then stops.
  • cwa_2 Aug 29, 2010
    Well, I to clarify the original statement of the problem: The motor and
    the drive screw both seem to work. But the *motor* stops after a little
    while. Sorry for the ambiguity. I'm thinking it is either the
    motor/drive screw assembly (motor stops for unknown reason) or the
    control console (sending faulty signals to motor/drive screw assembly). Also, as for the link (dated 2008) you mentioned, I'm not so certain that NordicTrack will believe I bought this unit 6 months ago at Cost Co, since it is a model which as far as I can tell, is *several years old*.
    Actually it is the motor that stops, and hence the drive screw. Either the motor-drive-screw unit is defective, or the controller in the console is sending the wrong signal, but I don't know how to trouble shoot that.
  • 3,247 Answers
I am assuming the problem is with your CX990 elliptical and has nothing to do with the E4000 treadmill.
To begin with you may want to try to lubricatet the key moving parts as shown in the user manual.
Next you could try to initiate the callibration cycle on page 22 of the manual.
The manual is detailed enough to work out which components are connecting the drive to the ramp. See if this helps.
Post a comment to confirm if this helped or not.
Posted on Aug 29, 2010
  • 3 more comments
  • Sam Aug 29, 2010
    not sure if you ran the calibrate function that i had suggested in y previous post?
    Yes, I've tried that. The ramp does move from about 25 degrees to 30 degrees or so, but it goes back down to 25 degreess, not all the way as the manual says it should. And all the appropriate parts are lubricated. I believe it is either the motor/drive screw unit, or the controller in the console, but I don't know how to trroubleshoot that.
  • Sam Aug 30, 2010
    unfortunately there is no specific diagnostic available from Nordic Track unless one is there qualified technician who will have the codes for testing at the component level.
    Most people would be left with no choice but to source the suspect parts and replace unless the unit is under warranty which I am assuming does not apply to your case. The parts are listed and available from this site. and also from Nordic Track site which appear to be cheaper.
    It will not be a cheap option especially because you cannot source parts of the console where the controller is - you have to replace the whole console.
    You may have to call a NordicTrack technician who will have access to the diagnostic codes but will obviously charge for service call to make a visit. Perhaps if you call the Nordic Track support and explain the problem they may suggest a solution on how to run the diagnostic.
  • 3,083 Answers
This sounds like the drive screw shaft is either loose or broken. The motor will have to be removed to ascertain exactly what the problem is. I couldn't find a diagram of this unit, so I have no idea of the exact construction, but it sure looks like it's going to be a problem with how the drive screw attaches to the motor, and that will be the thing to focus on. Make sure the drive screw only stops, and not the motor rotation, since that would indicate a bad motor or power feed.
Well, I just stumbled onto a neat web page that might just solve your whole problem. Read this blog:
http://en.allexperts.com/q/Fitness-Equipment-Exercise-3787/2008/1/NordicTrack-CX990-Incline-Motor.htm
It sounds like they'll both help you figure out the bad part(s) and replace them.
Good luck, thanks for using FixYa, and hope this helps.
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Precor 5.17i lift wobbly
INcline it all the way up and look underneath the ramp. Check where the ramp attaches to the main frame. If there are cracks in the bottom of the ramp, you need a new ramp, especially if you have a steel ramp as opposed to alumunum.
Mar 14, 2014 | Precor Exercise & Fitness
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Oct 24, 2013 | Exercise & Fitness
NordicTrack CX 1055 Elliptical ramp pedal wheels
Hi, You can find them easily on amazon, click here ant take a look: Amazon com Elliptical ramp pedal wheels. Wish you best of luck. Cheers
Jun 22, 2012 | Exercise & Fitness
I have an efx 546i and when I try to use the incline the panel states: No ramp, low battery
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Jan 03, 2010 | Precor EFX 546i Elliptical Version 4
NordicTrack E4000 Treadmill Logo
1,626 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
