Question about Logitech Z-5300 Computer Speakers
Popping & hardly any volume
First problem: when adjusting the volume, i would get a pop every click of the knob. it would get increasingly loud as the volume setting increased.
Second problem: speakers suddenly decreased in volume one day when I connected them to a laptop with an extension headphone cord. Since then, even at high volume setting, I get very little sound (but popping noise described in first problem is still very loud).
Third problem: static in two of the speakers.
  • 1 more comment
  • ob3n May 20, 2008
    I've the SAME problem... what the hell is that?!
  • scobbydoo May 29, 2008
    volume is set at high but we can hardly hear the damn thing.
  • mann214 Feb 24, 2009
    same popping problem with volume knob.
I had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
Posted on Aug 14, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
How do I replace a subwoofer potentiometer ?
If the 10k resistor is the variable volume one then change it.Some sub amp plates have epoxy all over the pcboard.Hard to remove type.I think yours is soldered to a sub pcb and need soldering experience to remove.
Sep 14, 2014 | Polk Audio PSW111 Speaker
How to increase volume
In Windows 8, lower right hand corner of the screen, you will see a small speaker icon (the system tray). Click on it and a volume adjuster pops up. You can figure it out from there.
Jul 25, 2014 | HP ENVY 23-1060 23" AIO Desktop PC, Intel...
How to increase volume levels in my PC with Windows 7 operating system?
STEP 1; Single click the volume icon in the system tray, usually at the bottom right of the screen
STEP 2: In thin window that pops up click the icon at the top
STEP 3: In the pop-up window, choose the 'Enhancements' tab
STEP 4: Click the box next to 'Loudness Equalization' so there is a checkmark
STEP 5: Click 'OK' and you're done
Sep 25, 2013 | Microsoft Windows 7 Ultimate for PC
How do i remove the volume icon from keep popping up onto screen
when the volume icon is pops onto your screen right click on it select delete also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | Computers & Internet
Amp pops randomly and gets worse with my remote bass knob hooked up any ideas ?
When you say that the amp "pops" are you referring to the sound that is coming out of the speakers?
This is most likely the speakers "bottoming out", i.e. moving as much as they can, and then slapping against the back of the speaker frame. Adding the remote bass knob (presumably increasing the signal to the amplifier) would make the problem a bit worse, which explains why the popping increases after you add the bass knob.
You can try decreasing the gain on your amplifier and running the system at a moderate volume. If there's no popping occurring, you can be reasonably sure that the subs/speakers are just being over-driven.
Mar 03, 2011 | Rockford Fosgate Power 1501BD Car Audio...
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Loud crackling / popping
Well gd stuart i think you need some new speakers
Jan 27, 2008 | Logitech Z-2200 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
295 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
