Question about Samsung NC10-14GW Notebook
During the boot up of my samsung n150 note book pc an error message is displayed "initialization logon has failed,click ok to terminate the program" after these error further booting isnot possible .what is the cause of this error?
SOURCE: SAMSUNG YH920GS- Error Message- device cannot initialize hdd
I have a YH-925 Samsung and this massage has been displayed for a several times. HOWEVER, the device hasn`t proved to be worthless!!! I`m sorry, but the previous comment has been obviously posted just like that, without any certain experience! Here it is. So, as you know, this is a really complicated electronic device and like all other hdd players, there are often errors in the softwear. Normally, by restarting the player, by pressing the RESTART button on the back, the device should be restarted. BUT, the problem is that it is not. You don`t actually stop the electricity that is running to the processor and that`s why certain false commands (causing the problem) are still running. And they will be, until slightest electricity in the battery is left. I cannot be sure that your problem is that sort of, because you may have ,for example, dropped your player so badly that the Hard Drive got corrupted. I cannot help here. But these Hard Drives are actually preety reliable, so the possibility to have it seriously damaged is not much likely. How do I repair my player? Of course you should first of all try to repair the device by using the Recovery Utilities by Samsung (you know, holding >> (forward) while connecting the switched off device to the usb). If this doesn`t help, read further. Operate very very carefully! Open the player by removing the back cover. Remove the HDD. Disconnect the battery and than connect it again. Now the electricity in the processor has been stopped and old commands are canceled. Make sure everything is on place and watch out that you don`t damage the battery`s cable. Than attach the Hard Disc to the motherboard again. Be careful, watch out that it connects to the board. Close the player. Start it. Hopefully, it loads the boot programm and your problem is solved up. I reccomend repairing the HDD by using the Recovery Utilities, (you may also format it, but you`ll lose all data). Actually the same problem may occur again, there is no guarantee. I have had it three times until now. Please notice that the song titles should be written in latein (english). I had some in cyrillic, and this probably drives the player crazy, since it doesn`t recognize the alphabet. PLEASE mail me, if I managed to help you sort it out! I`ll be delighted! GOOD LUCK
Posted on Jun 22, 2006
  • 10 Answers
SOURCE: initial fail error
The HDD is disconnected from the player. When you open up the player just carefully push the circut board thing on the gold foil behind the hdd in untill it clicks.
Posted on Jan 01, 2008
SOURCE: SGH J600 JAVA ERROR!
I had the same problem. It was solved by making a new jad file with jadmaker and using that instead of the original jad file.
Posted on Mar 15, 2008
  • 285 Answers
SOURCE: Boot problem
Reinstall your operating system. First start p with the method you described, then backup all important data. YOU WILL LOSE EVERYTHING ON YOUR HARDDISK SO BACK UP IMPORTANT DATA AND PROGRAMS, OR YOU WILL LOSE THEM!!! Then insert the disk with your Operating System, and restart the computer. Boot from the disk and install the OS. After that you can reinstall your prgrams and put your data back on it.It should boot fien from now on. If not, please post back here. I hope this helps, Yannick.
Posted on Jun 08, 2009
flipbooks
  • 177 Answers
SOURCE: Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Posted on Jul 31, 2009
How to control Samsung note book computers screen brightness?
You have not mentioned the OS name or version.
Appears to be display driver issue.
See the forum here http://www.sammynetbook.com/forum/threads/13405-N150-unable-to-adjust-Brightness
For windows 7 ... Try the version 8.14.10.2108 from Samsung site and apply it (Run As Administrator required) and after a re-boot ]. shoud solve
For windows 8 ... follow http://www.eightforums.com/general-support/3281-samsung-n150-cant-change-brightness.html
Jul 27, 2016 | Samsung N150 Notebook
When i switch it on it boot alright the after booting it tels me that logon process initilla
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 10, 2012 | Samsung N150 (36725723009) Netbook
How do I clear my info so I can sell the machine
  1. SYSTEM= (Firmware ID) - Press [BACKSPACE] to initiate the destructive
    memory test.
  2. MEMORY TEST MEM WILL BE LOST PRESS FUNC IF OK - Three prompts are displayed to warn you that a destructive memory test has been initiated, and to inform you that the contents of the SRAM will be lost if you proceed with the test.
  3. Press [FUNC/ENTER] to proceed with the test. To end the memory test and return to the System Prompt prompt, press any key on the core keypad other than [FUNC/ENTER].
  4. MEMORY TEST (or) MEMORY -OK- (or) MEMORY ERROR - The memory test runs continuously until you stop the test. During the test, the message displayed on the terminal
    screen alternates between MEMORY TEST and MEMORY -OK-. The message MEMORY -OK- indicates that no memory problems were detected during the previous test.
    NOTE: If a problem is detected during the test, the error message ***BAD RAM*** is displayed. If you see this message, contact your local VeriFone representative for assistance.
  5. To stop the test, press any key while the MEMORY -OK- message is displayed. The message MEMORY ERROR is then displayed to indicate that the contents of the memory were erased during the test.
  6. Press [CLEAR] to return to the System Prompt.
Feb 14, 2011 | VeriFone OMNI 3200 (P092-101-10) Printer
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
How to delete access denied files?
Install and use  http://ccollomb.free.fr/unlocker/
Mar 16, 2010 | Microsoft Computers & Internet
I can't logon my note book,NEC versa S9100 and pop up below message. The systemevent notification service service failed the logon. An attempt was made to reference a token that does not exist.
Sounds like you have a corrupted operating system. Virus or trojan.
Sorry but it looks like you need to reformat hard drive and reinstall WinXP
Apr 26, 2009 | Computers & Internet
Error message on laptop boot up
You need to reinstall the modem driver ..
Dec 12, 2008 | Computers & Internet
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Samsung NC10-14GW Notebook Logo
145 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
