Question about Alpine Car Audio & Video
I have a factory radio from a 99 Eclipse. I installed the stereo, it's asking for a code?
  • 5,081 Answers
All you need is an radio unlock code to get it working.
Radio code is specific for each and every car. It is specific like anti theft code.
You can get it by providing your VIN# and registration details in authorised dealership.
Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car..
Posted on Aug 29, 2010
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
Need code for 2000 mitsubishi eclipse radio
Mitsubishi codes are only available from the Main Dealer or a Radio Decoding Service.
They are not available for free as access is required to the original factory database ...which is not commercially available....Sorry
Apr 17, 2010 | 2000 Mitsubishi Eclipse
Need the code for the radio
None of the mitsubishi cars stereos have the same code, I had this problem with the stock stereo on my 99 eclipse spyder, I removed the stereo and put an aftermarket in, but changed it back when I was trading the car in, You have to call mitsubishi customer sevice with the serial code number on the back of the radio, also you have to provide them with information to prove that you actually own the car.
Jan 16, 2010 | 2000 Mitsubishi Galant
Need code number for 2000 mitsubishi eclipse to turn radio on
this is quite a common fault which i hear, the only way to obtain the code is to hope the previoous owner or the person who fitted stereo is wise enough to write it down in your handbook. if it a factory fitted stereo then the manufacturer keps a log of it and will provide it to you for a small fee.
Feb 25, 2009 | 2000 Mitsubishi Eclipse
Factory stereo code
Factory radio codes are an anti-theft deterrent, they are unique to each radio and car serial number, in order to get the code the dealer will have to access the manufacturers data base, you will need to pull the radio and record the radio model number and the serial number of the chassis of the radio and take it to the dealer, they will not in most cases give the info out over the phone, this would defeat the whole purpose of the code.
Oct 18, 2008 | 2000 Mitsubishi Eclipse
Had dead battery. Now radio says I need a code to unlock it.
What type of radio is this? If it is aftermarket, then typically Eclipse and Kenwood are the only units that utilize radio codes. If it is a factory radio (Honda, Acura, Audi, VW typically), then you will need the code which is 4 or 5 digits long and located in your owners manual or vehicle documentation on a small card the size of a credit card. If this is unavailable, then you will need to visit a local stereo shop, have your radio removed and re-installed, and your serial number written down. Take your radio's serial number to any dealer for your car manufacturer, and they will provide you with the unlock code. Hope this helps.
Sep 03, 2008 | Audio Players & Recorders
Radio code
I had the same problem. Dealer will fix but they want ridiculous amount. Call Mitsubishi customer service. They will need info: Serial number and model number of the radio. The numbers are on the side or back of the radio (Easy removal-just need a screwdriver). Also they ask for proof of ownership Fax it over to them, then call back for the code. Its easy and its cheap.
Aug 17, 2008 | 2000 Mitsubishi Eclipse
2000 Eclipse Security Code
all you have to do is call a local mitsubishi dealer and ask for parts department and ask for the code. but first you must remove your stereo and serial number and i forget what she called the other number, just dont do what i did and just randomly enter wrong numbers your radio will lock up and i dont know what to do now
Jun 18, 2008 | 2000 Mitsubishi Eclipse
Car Audio & Video Logo
111 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
