Question about Whirlpool Duet GHW9150P Front Load Washer
Washer leaks during spin cycle; rubber insulation becomes displaced..what do I do?
  • 28 Answers
Remove the lower access panel and check to see if one or more shocks are broken or diplaced. You may have a steached spring causing the bellows to come off in the spin cycle.
Posted on Aug 29, 2010
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
Codes and holes
Hi mandystreet,
I’m an owner like you; from what you describe I feel you have a clutch issue if you’re machine is a FAV6800AW or FAV9800AW. I'll bet it completes the spin cycle with no clothes in the wash basket. Here is what is happening
See this post for a step by step process to remove the clutch. Try a maintenance clean up of the One-way Roller Clutch bearing and see if that will get you back in service, if not I would do a Clutch replacement.
Your machine is shutting down the spin cycle with dc and UC errors so your Tub Displacement Sensor is working as designed.
From the Service Manual page 12;
During fill cycle – If machine tumbles and spins simultaneously replace clutch assembly.
During spin cycle – If machine tumbles and spins simultaneously replace clutch assembly.
You can check this out by turning off the water supply lines if you check during water fill cycle. Lift the washer top from the base and observe the action during water fill or spin cycle. The Service Manual will show you how to raise the washer top from the base.
This is happening because the clutch One-way Roller Bearings are sticky, slightly rusted. When the machine enters spin cycle the agitator shaft is slightly engaged because the one-way roller clutches are dragging this will cause the agitator shaft to rotate in spin cycle spinning the tumblers slightly. In this condition the wash load is tossed about while the wash basket begins to spin up. This will cause the Tub to become unbalanced and the tub starts making greater swings.
This continues until the TDS (Tub Displacement Sensor) signals an unbalance condition to the Control Board and shuts the cycle down with a dc or UC unbalance errors. If the TDS fails in this mode the machine would likely walk across the floor until it unplugged itself or ended in a self-destruct.… :)
A WD-40 clean up and re-lube may get you back in service. Just follow this posting step by step. If you are not a DIY type direct your service repair to this e-mail to help speed you to repair and control cost. You can redistribute the wash load until the cows come home and you will continue to fail with UC or dc unbalance errors…. Fix the clutch issue and your machine will be happy and so will the owner.
Rich
Sep 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Jul 06, 2009 | Washing Machines
Leak during rinse and final spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 20, 2009 | Washing Machines
I have Frigidaire front loading. During the spin
During fill only
All the time
Apr 03, 2009 | Frigidaire Washing Machines
Washer leaks
Hi!
During fill only
All the time
    Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Feb 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water comes out of soap dispenser
http://www.applianceaid.com/neptune.html click this link and click the required option in the link Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
Jan 27, 2009 | Maytag MAH6700A Neptune High Efficiency...
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
