Question about Acer Computers & Internet
Hi there buddy. I have an old Acer 3634 LMi laptop that works well except for the monitor. The display is all black but there is a faint showing of light, so I am lead to believe that it is the backlight that may be faulty. By the way, I have had an external monitor connector attached and working fine, but just did a complete reset back to factory settings, which has turned off the external monitor. First is there a way to reset the external monitor settings so I can use it now, and secondly I need some help with replacing the backlight. I have pulled the cover off and am now a bit puzzeled as to what to do next. Appreciate any help you can offer. Thanks Matt
  • Acer Master
  • 32,281 Answers
To determine the backlight problem and possible fix, please click on this link and follow my instructions :-<br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen">http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen</a></span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"></span>
Posted on Aug 29, 2010
  • Chris Hingee
    Chris Hingee Aug 29, 2010
    http://www.fixya.com/support/r3598095-fa...
Acer aspire as5052an wxmi
Does it seem like the laptop booted up except the screen is black? if so, try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 08, 2012 | Acer Computers & Internet
My acer aspire laptop 5336-2524 worked fine until today when i turned it on everything works fine except the screen stays black. What can i do to fix this
May 01, 2012 | Computers & Internet
Cannot open my laptop,acer aspire 4720 zo1 series
Totally No Display? Is the laptop running? Do you hear fans running, disk drive spinning and lights? If it seems like the laptop completed the boot process except the screen is black, try this:
Shine a flashlight on the dark screen to see ifyou barely see the icons on the desktop. If so, then the LCD Inverter isbad.
Apr 19, 2012 | Computers & Internet
Hi, I have a T400 and when I trun it on the Thinkpad black screen appears and does not change. Please can you help
Does it seem like the laptop is running except the display is black? Do you think it booted all the way except the screen is black? Do you hear fans running, disk drive spinning?
Apr 09, 2012 | Computers & Internet
Display Shows on External Monitor, but very faint
one of two causes : inverter board damage ( Replace it) or backlight lamp damager (also replace it).
May 09, 2010 | Toshiba Satellite A135-S4527 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Screen
if you trashed the screen than you should see black, you may have did some thing to the monitor screen it may have an internal fuse link inside the screen display, the the connects at both end of the monitor connection missing, broken pin or connectors, mis aliegned connection, bitmap convertion system or the GUI portion is fualty some how.
testing a monitor or screen software call sonera technologist software called displaymate for windows a daignostic program for monitors,
you may bee able to find other software at some of the computer download center for free like pc world download software.
rod
Feb 04, 2009 | Aspire Acer 7520-5324 Laptop
Acer al1711 shows only a white screen
These are pretty old now but I'll respond anyhow-
When there is absolutely no screen content and white, it means that ALL pixels are turned off; black, means all are turned on. If you have a white screen, it means that a component in the video stream has failed; a black screen (preferable failure!) often means that the backlight lamp or its inverter have failed. The latter is a potential DIY fix, a dead IC in the video path normally not since most of the signal chips (ICs) are placed and soldered by robots and the pin spacing on those is pretty much beyond the capabilites of an untrained hand.
The only exception I can think of is if the ICs no longer have voltage supplied to them from the main power supply but you would need at least a cheap multimeter to locate that.
May 31, 2008 | Acer AL1711 17" LCD Monitor
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
Acer aspire 3634 LMi
Do you get any beeping or flashing status lights when you try to start it up?
Nov 15, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
