Question about Maytag Washing Machines
Keeps saying nd and will not drain - Maytag Washing Machines
  • diannabrierl Aug 29, 2010
    We are going to look at the pump tomorrow. it is late, but will l let you know tomorrow what we find in the pump.
  • diannabrierl Aug 30, 2010
    It was a nail that would be used to hang a picture with!!! Once again, thank you so much!
  • 5,081 Answers
The ND code means 'No Drain' and it is probably just something caught in the pump. I’ve seen where a coin can get in there and keep the pump from starting.
Some other items known to stop a Neptune pump: Rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump? If so, please comment with what you discovered in your pump...
If you have a floor drain you should be able to drop the discharge hose to the floor and let gravity pull the water out so you can take the pump out and get a good look at it.
Posted on Aug 29, 2010
Samsung washer WF419AAU/XAA nd error code
What detergent you use could be causing suds to stay on the machine sensor and it thinks it has not drained. The only other things are the elevation of the drain hose and the sensor itself.
Mar 24, 2014 | Washing Machines
I have a WF328AAW washer and it drains yet the nd code appears after
Find the drain sensor, it will be somewhere low in the plumbing. Check to see if it is dirty, check it electrically, too.
Nov 24, 2013 | Samsung WF328AAW Front Load Washer
Amana front load washer
nd--Washer is not draining/Washer senses a brief restriction while draining
Nov 17, 2013 | Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi; I have 55FLBWW and the np light keeps flashing, and will not go any farther.
Are you sure its NP and not ND the nd is for not draining, either your pump filter is plugged of the pump is clogged up and needs cleaned out, coulsd aslo be your drain hose. Best way to check is use a shop vav on the drain hose and **** up all the water you can that way, then take the filter cover off the pump filter (in front and under the bottom cover) and check for pluggage, if none is there then the pump may be clogged or not working.
Mar 12, 2011 | Maytag Neptune Washer
Door will not open and keeps reading nd on screen i have unplugged but still will not open
the nd on my Maytag means: The washer experienced difficulty draining,
check for a kinked drain hose
check for a plugged stand pipe
Jan 23, 2010 | Washing Machines
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
