Question about Avid Xpress Pro - (bundle) (05600360101) Video Capture
No bounding box showing up to move
Running short of hard drive only 6 gigs left of 250. No bounding box shows so I can not move clips.
  • Jim Crawford May 09, 2008
    Thanks but I have resolved this problem. I deleted render files for other projects through the menu under project. This gave me plenty of memory on the C drive.
    However, I do have another problem related to boot up of Avid Liquid 7. I get message on boot up of: Cannot load Adorage support-library. Please install the new adorage plug-in. I click it 3 times and it goes away and the boot up continues. And I guess related to this is that I can not get the Smart Sound generated music on any clip. Any suggestions on this?
  • Anonymous May 11, 2010
    Are you able to move the files one at a time?
How do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Mar 11, 2011 | LaCie (300770) 250 GB Hard Drive
Its a 250 gig hard drive and its saying that the memory on the hard drive is a 14.9 gig hard drive. it won't allow for it to put windows 7 back on it. It says there are no drivers on the hard drive on...
This hard drive needs to be repartitioned and formatted first then you should see actual amount. You can do this when selecting the drive in windows 7 installation
Make sure the drive is listed in the BIOS matching your serial, model number, etc incase you purchased this from ebay or second hand.
Mar 11, 2011 | Samsung HM250HI 250 GB SATA Hard Drive
My drive wont show on my computer and it makes a sound like dropping a ball bearing inside it. I cant access the drive to move my data off from it. it is an IOMAGICK external Sata high speed USB 2.0 250 GB...
Sounds like it has the "Click Of Death" if you have something on there that you really need it may be possible to run it for a short while after freezing it (wrapped in plastic film) if you're lucky. More than likely though it is destined for the bin.
Jan 05, 2011 | IO Magic Corporation GigaBank (I250HD35)...
When I plug in my Lacie external hard drive to my computer, it freezes up the Computer window when I am browsing my drives. Eventually it shows up, but shows that it has no files on it and doesn't say how...
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 03, 2010 | LaCie (300770) 250 GB Hard Drive
Unable to access space on Lacie remote drive
The easiest way will be to format the disk drive. Highlight the icon, right click and format.
Feb 07, 2010 | LaCie (300770) 250 GB Hard Drive
I have a insperion 8100 laptop, I replaced the 20 gig hard drive with a new 100 gig drive. my bios is the latest update A15. It wont reconize the new hard drive, F1 and F2 will give me the same info no...
Sounds like the new drive is not "Initialized" The drive should have come with software that initializes and formats the new drive. After installing the new drive, boot the computer with the included software disc. Seagate and western digital have software that comes with their drives. If that is not possible, the other way is attach the drive to another computer, access the control panel > Administration tools > computer management > scroll down left pane and select "disc management" > this pane will show all hard drives on your system, including the new one. If the new drive does not show a partition in the right pane, then you have to RIGHT click on the name of the drive, which is the small tan box to the left of where the partition would be and select "Initialize" this is done immediately and is active waiting. Disconnect the drive and re-install in the laptop.
Aug 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Installed a 250GB WD Scorpio and it shows as a 130GB drive
make sure the laptop will handle a drive bigger than 130 gig. if not make two partitions when you set it up, bios wont see it but usually windows will. also, sometimes ive found that if i delete the partition a few times it eventually reads right. dont know why but have done it that way several times. you can also download a diskmanager program from thier website which makes an overlay if your bios wont support a 250.
Aug 23, 2009 | Western Digital Caviar WD2500BB 250 GB...
Exterinal hardrive wont show up on computer
Try it in another computer, if it doesn't work on anoither computer, it may have died
Apr 17, 2009 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
250 gig WD EHD
try to right click on "My Computer"->Manage-> Disk Mng.
Then try to see if you can recognize you this disk.
maybe you just need to change the letter or format it.
Apr 05, 2008 | Western Digital My Book Essential Edition...
Moving files
just go to All programs<Accessories<System Tools<Backup. and choose the option you want.Once you have choosen what all you want to backup than you can choose the option for the place where you want to back it up.
Hope that works!
Dec 27, 2007 | Computers & Internet
Avid Xpress Pro - (bundle) (05600360101) Video Capture Logo
289 people viewed this question
Top Avid Televison & Video Experts
Are you an Avid Televison and Video Expert? Answer questions, earn points and help others
