LG MODEL F1203CDP WASHING MACHINE FRONT DOOR BOOT SEAL PART NUMBER
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: Frigidaire washing machine collects water behinf door seal
Frigidaire has several mfr defects with their new front loading machines. The detergent/bleach drawer retains water, the door often leaks, water does accumulate in the door seal and the spin has broken twice on us and the machin is only 15 months old! Repair is contracted out by Lowes to independant repair companies, who demand payment, even when Lowes says it is covered under warrantee. What a waste of a large amount of money! We will NEVER purchase Frigidaire or recommend their products to anyone.
Posted on May 11, 2008
  • 3 Answers
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
I don't think it is easy to remove it, but you can clean it with white spirit or something similar.
Posted on Oct 29, 2008
VtToolMan
  • 704 Answers
SOURCE: im needing to know how to install the replacement
Candie, The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20Sub%20Components%20list
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
LG HE Waher model WM2010c, rubber door seal slid and distorted the seal edge, on a spin cycle with a towel in it, how do I fix this?
If seal/boot is not torn, then remove front spring/wire clamp, reposition the seal/boot, reinstall the spring/wire clamp. Check out repair videos at appliancepartspros.com or repairclinic.com.
Feb 01, 2017 | LG Washing Machines
I am a novice. How do you replace the outer seal on the main large drive wheel, please
what maker of machine and model
there is a lot to undo to get it right
on a front loader I cant find a step by step
how to diy for a front seal renewal
watch this youtube if not clear for you ..its an LG front loader
ring a washing machine repairer
Washer Leaking Water LG Front Load Washer Door Boot Seal Replacement part...
Sep 22, 2016 | Washing Machines
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My Kenmore front load washer, model #796.4884 needs new seal. How do I replace it? I have new seal
Assuming you mean the rubber door seal...
There is a very good video here, the basic principles apply to your model but there will be differences. Watch it and decide if you are confident to proceed. Don't forget to unplug it first Door Boot Seal part 4986ER0004F LG Kenmore Washer Repair
You could contact sears for exact instructions?
Jun 27, 2014 | Washing Machines
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
I have New LG F1203CDP washing machine. whenever I start my washing Machine and after 5 mins from the cycle, the electricity will shut down automatically. Electrical technician confirmed that their is no...
If the machine is new, as you stated, before messing with anything, call the store or dealer where you bought it, and address your concern, doing anything to the machine itself may void any warranty that they may have for you on it
Jul 08, 2011 | LG WM2233H Front Load Stacked Washer /...
How do I replace my door boot seal/door gasket on my LG WM1832CW front loading washing machine?
There are 2 springs attaching the door boot. The springs are really tough but there are 2 separat tools for each spring. Use the tools to remove & install. It's tough but can be done.
Nov 10, 2009 | LG WM-1832C Front Load Washer
Machine is leaking out the front door
Check door boot seal for ripping/ holes in it
Sep 28, 2009 | Washing Machines
Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Jul 21, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
