Question about InFocus Office Equipment & Supplies
Infocus x6 has moving diagonal lines when projecting from dvd player. How can I fix this? I am very much a layman, so please answer in simple terms. Thanks!
  • 1 more comment
  • blricketson Aug 29, 2010
    thank you, but I don't completely understand. I have used another dvd with this projector with the same results. How do I ground the projector? Right now, it is set up in a theater space and hung from the ceiling, the wires are then run to the booth where I have connected it to the dvd player. It is plugged into an outlet strip. Thank you.
    Thank you.
    thank you- this might very well be it, I will give it a try.
  • InFocus Master
  • 17,130 Answers
Possible that the noise you seen( Video noise) is ccoming from the DVD player.
Most often the connecctingg RCA cabbles can be have poor shield orr damaged wires. So connect them tight with the ground tight. If the noise appears reverse the plug of the DVD after switching off.
If the fault wont clear, try to use another device on this port to confirm( another DVD player will be good.)
If the fault disappears then the noise is coming from the power supply of your player --possible failure of filter capacitorrs in the power supply,producing transcient voltage.
However if the other DVD also gives this noise, try to ground the projector, if there is no result then it is possible that the Video input socket has a ground failure in the board.( hope there is no issue with the PC)
If there is fault with all connections to the projector then it is possible that the board are not grounded or there is failure in power filtering. Check on power supply.
Hope these tips help you to make the tests.
Posted on Aug 29, 2010
  • Donald DCruz
    Donald DCruz Aug 29, 2010
    If the cable is running a good length( Theatre setting) then it is possible that the input cable is picking noise. reduce length or connect a DVD close to the projector and test. if so change the wiring.
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
In laymans terms ! got a bush 1080p tv, but when
1080P resolution is only avalable with BD players, Upconverting DVD players,Some media players and some satellite PPV movies.
Nov 18, 2009 | Bush Televison & Video
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Image from the DVD play is distorted diagonla lines that keep moving
have you tried another dvd player on the set just to rule out that it is that dvd player its probally not worth fixing and i'll tell you why these things are a dime a dozen any more ok good luck
May 22, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I accidentally deleted my power dvd player from my computer.
you can try to download the version you had if you remember which one it was. If you do go to google and type in power dvd the version and it should come up.
May 07, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Lcd monitor to dvd player
Hi , You need to have external TV tuner card and then you will be able to connect to a DVD.
Jan 11, 2009 | Microtek 815C 18" Flat Panel LCD Monitor
HELP
jennyd8,
I'm not sure exactly what you are asking me to explain. If you are asking why it has to be locked or "frozen" in the DVD mode it is because that is the easiest way to effect the fix, ie, by wiring the new connection to the cable that comes from the DVD player into the motherboard. If your set is already "frozen" in the DVD mode then you are ready to start the fix. If you need to get it in the DVD mode just stick a DVD in the player and the set will go into the DVD mode. If this is not what you wanted clarification on then please be more specific as to what you are puzzled by.
bintzi
Apr 28, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
Problem with projection Infocus 5700
the light tunnel has collapsed and part of it is blocking the image. find an infocus service center to have them fix it because they don't sell the part.
Oct 27, 2007 | InFocus ScreenPlay 5700 Multimedia...
Sony with diagonal lines
Is it a composite(yellow plug)video input? an HDMI input? What if you switch the output of the cable box to another input, Make sure its not the cable box first. If it happens on another input then the cable box or the connection wire to the tv from the cable box is bad.Good Luck Ps Please rate this thread
Oct 18, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
184 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
