Question about Goldstar LG L1004R Window Air Conditioner
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
  • Goldstar Master
  • 17,129 Answers
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Posted on Aug 29, 2010
Making a noise and spitting water inside
your ac unit may not be installed properly, it needs a 1/4 inch tilt to allow water to drain properly outside. Also make sure your drain plug is open to allow the water to drain out.
Apr 25, 2011 | LG Heating & Cooling
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
Ac making noise
sounds like the drain is clogged, it usually comes out if the outside of the unit just below the coil in the middle of the back, there may or may not be a hose attached to the front pan below the evaporator, try pressuring it up to blow it out. worst case you may have to remove from the window, disassemble and clean. hope this helps...
Jul 18, 2009 | Heating & Cooling
2003 passat sedan. water on floor and in heater fan
I don't think it has anything to do with the sunroof. I think you have a leak either around the windshield or under the cowl where the wipers are attached. If it's in the cowl area probably over the blower motor housing on the right and the water is following the vent system to the drivers side. Please let me know how you made out.
Thank you
Jun 04, 2009 | 2001 Volkswagen Passat
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
AC is spitting out water inside. Where are the drain plugs?
I have the same AC and had this problem. Sludge builds up inside the bottom of the unit from dust and water build up causing it not to drain and the fan spits the water out. Its a fairly simple fix with a philips screw driver and a wet vac. Unplug the AC first. Remove the AC from the window. Remove the screw inside the front panel below the filter screen. Then you can pop the whole front panel off by pulling it with a little pressure. Now you need to remove the 3 screws holding each of the slider panels onto the side of the AC. Then remove the 3 screws on the bottom of the left and bottom of the right side of the AC. Remove the 3 screws holding the bar on top of the AC. Lastly remove the 2 screws on the back of the AC in the bottom Left and Right corners. You can now pull the top cover off. You can now use your wet vac to vacuum out the sludge that is in the bottom of the AC from the right and left side. There's a ground wire that connects from the fan motor to the bottom plate of the AC, be careful not to hit it. I knocked mine off possibly to it having been rusting in the backed up sludge and had to strip the wire and reconnect it.
Jun 02, 2009 | Heating & Cooling
Friedrich air conditioner
I used to be a "Factory Authorized" person, and I bet Friedrich would rather do a warranty call than have you return the machine for a refund. Phone them to see if they are cooperative. When the tech gets there, you can ask ALL your questions and point out every little sticky thing. That's his job!
The tech will be able to get parts and know how to adjust things.
For the second person, you have to look into the space where the fan is hitting something. A mirror and a flashlight will be needed. I kind of get a feeling the water isn't draining fast enough. Look for a plastic tube from the front water pan to the rear water pan. They get plugged up.
Jul 24, 2008 | Goldstar R1003 Air Conditioner
LG air conditioner spitting out water through vents
Hi Mia
I would worry about coolant .. your problem is that the drain in on the outside is pluged or the AC is not installed correctly and is not draining to the outside as it should...
hope it helps
let me know
Apr 07, 2008 | Heating & Cooling
Goldstar LG L1004R Window Air Conditioner Logo
482 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
