Question about Panasonic CT-36HL43 36" TV
Won't turn on
We were watching TV turned it off, 20 min later it wouldn't turn back on. Have power at the outlet. I read that it could be a fuse is this something that a homeowner (computer Tech) could replace and if so where is this fuse located?
  • ibtrkn2 May 08, 2008
    FIXED!
    Champion:
  • 252 Answers
It is located near of the ac cord (wire)
Posted on Sep 29, 2008
  • Demonic-2011
    Demonic-2011 Mar 10, 2011
    Lucky it was something simple like a fuse replacement, and not a massive power supply repair.
I let my tv play all night long i turn it off then 5 minutes later hit the power button the blue indicator light comes on but no picture or sound i play with the power button and sometimes it just turns...
you must check the power supply unit of the tv which may have bulged capacitor at the secondary output which may need to replace due to it was leak.
Nov 01, 2013 | Sceptre "42"" Lcd 1080P Tv"
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Turn tv on watch it for 20 mins. screen shuts off but green power light is still on. turn it off manualy wait a few mins. turn back on watch for anouther 20 mins or so then screen shuts off again
The reasion your set is shutting off is because the power supply is dieding, and you need to replace the electrolytic caps on the power supply, or purchase a new one, go to www.partstore.com sand check to see if they have your power supply.
Aug 17, 2011 | LG 50PX5D 50 in. Plasma HDTV
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Tv wont turn on.
try cutting power off and wait 15 to 20 minutes. also try another outlet depending how much power u r pulling thru the outlet u had it in. Had same problem and customer service said unplug for 3 min....not long enuf...so try 15 to 20 min and plug back in.
Apr 10, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
T V turn's off on its own
check your set. maybe you turned on SLEEP. it will automatically turn off.
Oct 16, 2007 | Philips Magnavox 20MS233S 20" TV
Panasonic CT-36HL43 36" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
