Question about Asko 24 in. D3530FI Built-in Dishwasher
Two grey plastic pieces came loose. Don't know where they belong inside the dishwasher?They are both the same. They apparently hook onto something on the rack, but I don't have a clue?
  • 28 Answers
If these two grey pieces are about 1 1/2" long and a 1/2" wide. They are used to retain the upper rack onto the tracks to prent the rack from falling out and used as a rack stopper. There are two on the front and two on the back of the top rack. How to insert them may differ dependant on the model. look at the two still attached and you may be able to re-install them.
Posted on Aug 29, 2010
Normal + rinse light flashing on dishwasher
it sounds like something has came loose. you have to take the control panel apart and you should find a grey flat plastic cabel about 2 1/2 to 3 inches wide.hook it back up and maybe use some electrical tape to keep it in place and that should fix it.
Apr 15, 2014 | Whirlpool 24 in. DU1100XTPS Built-in...
Detergent dispenser piece fell off and now will not lock closed. I have a grey piece and white piece, both plastic that I found when I noticed the flap would not lock closed. Is there a diagram avaiable...
Hi Ron,
I found your users manual, if you don't have it, HERE. The only thing I see inside is the clip to hold the compartment closed. Go HERE for the parts list, look on the "Door and Latch" parts, you will see no. 8 is the detergent dispenser you refer to. You may go HERE to find the replacement part. The cost may be scary tho, so it is entirely up to you if you wish to go this route.
Hope this is of help, Please rate and comment, Thank You, Joe
Sep 16, 2011 | Maytag MDB7609AW Builtin Dishwasher
I forgot to open the dishwasher hole when installing. I don;t have the instructions and I can't figure out what I am supposed to do. It seems solid and I don;t see anything removable
If you disconnect the dishwasher hose from the disposal and peek inside the disposal where the hose was, you'll see that it's blocked by a piece of plastic. It's premolded into the inner chamber but that portion is breakable. Stick a screwdriver or something into the hole and give it a whack. If that piece end up inside the disposal's main compartment, you'll need to get it out. You could turn the disposal upside down if you haven't already installed it, but you did.
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My yamaha PSR-310 portable keyboard keys are not working properly or sometimes not working at all... i tried to fix it but it was just temporary.... there are loose or cut connection for the keys not to...
Hello Don
I fixed my PSR-310 by cleaning those contact and adding a small bits of soft foam on the top of rubber grey cover.
It is easy just cut a small piece of foam and put in the cavity on top where the plastic note hit the grey rubber boot. Adding the small piece of foam compensate for the wear of the carbon contact inside the rubber boot. now my keyboard is working perfectly.
good luck
Sep 15, 2010 | Kitchen Ranges
Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Apr 06, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
I moved my PS3 from one area to another area. When I hooked it back up the TV read that the PS3 was not turned off properly. My wife told me that she turned it off. But was incorrectly turned off...
Sounds like there is something loose inside of the dvd drive especially if it wasn't accepting discs before.
If you are savy enough, go inside of the ps3 and remove the dvd drive. Then unscrew the screws to the dvd drive, when you open it up there will be a white plastic piece on top that holds the dvds in place so the drive can read it, this piece might just need to be realigned properly.
If its not that then check to see if there is any loose debris in there and remove it, then put the screws back on the drive, hook it back up to the ps3 then put the top cover back and try the drive again. Should be okay at this point.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Broken rollers inside top rack slides
We got rollers recently from Johnstone Supply, 501 Third Avenue, South, Nashville, TN telephone 615-259-3440 or 254-0702. I don't know the cost, but I'm pretty sure it was not $72. I suggest that you have the model #.
I am planning to buy some for another dishwasher at the moment.
Feb 20, 2009 | Dacor Epicure EDW24 Built-in Dishwasher
Dishwasher needs repair
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
May 28, 2006 | Roper 24 in. RUD5750DB Built-in Dishwasher
Asko 24 in. D3530FI Built-in Dishwasher Logo
194 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
