Question about Car Audio & Video
Kenwood kac-646 manual book - Car Audio & Video
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this helps. Thanks for using FixYa.
Posted on Aug 29, 2010
My Kenwood kac9152D turns on but why dose the red light on the top keep flashing?
The manual only says the power indicator burns when the power is on.
I can't find anything about it also should flash. The only thing I can think of, it has detected an error, like a blown amp or a low impedance on a speaker terminal.
Here is the manual:
http://images.kenwood.eu/files/prod/29/5/KAC-9152D_9102D_8152D_8102D_(EN).pdf
Jan 17, 2015 | Kenwood KAC-9152D Car Audio Amplifier
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
Kenwood repair manual
I have the Kenwood KAC-9152D Repair Owners Manual. This is my E-Mail address. canalv11@gmail.com send my a e-mail. & I will e-mail back 2 U w/the Manual ATTACHED
Dec 21, 2011 | Kenwood KAC-9152D Car Audio Amplifier
I need to know the wattege of a kenwood kac -624
The KAC-624 is a 40 watt x2 @ 4 ohm RMS amp. 55 watt x2 @ 2ohm. 110 watt x 1 Bridged I assume at 4 ohm. Manual does not specify. It can run 2 ohm in stereo mode but is unclear on mono impedance requirement. It can run 4 ohm mono at 110 watt but at 2 ohm?
Dec 12, 2011 | Kenwood Car Audio & Video
Wiring diagram kac-646 .Would like to make sure wire connects are wright
www.retrevo.com/s/Kenwood-KAC-646-Amps-review-manual/id/479bh244/t/1-2 check out this website and click on the download manual button. hope this is what you are needing
May 10, 2010 | Car Audio & Video
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood manual
Here is a free manual, just download it.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e73fb2d3135db11ba752b002abe6f643&q=Kenwood+KAC-748
Oct 30, 2007 | Car Audio & Video
Car Audio & Video Logo
152 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
