Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
AFTER 2 MINUES STARTS BEPING AND SHOWS LE IN ITS INDICATOR
  • 28 Answers
LE error is related to the motor
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked
I would suggest you contact a repair person
Posted on Aug 29, 2010
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
I have front loading DWDS1013 washing machine. When loaded and started it shows LE. We make sure that door is properly closed and restarted. Still it shows LE. Water supply is not changed and is like...
'LE' stands for 'Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 25, 2011 | Daewoo Washing Machines
LG WD12317RDK SHOWS FAULT LE
'LE' on LG's stands for Lock Error and indicates, not surprisingly, there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 19, 2011 | LG Washing Machines
Ultralite 480 lacks power, new batteries fitted 5 months ago, shows fully charged, dips down when accelerator lever pressed but stays in green area
The battery lights dropping down while the scooter is in motion is normal; the motors are drawing current from the batteries which is going to drop the battery level slightly. However, if you see the battery indicator lights dropping off steadily while the scooter is in motion (1 bar every few minues or seconds) this can indicate a battery problem. It sounds like this is normal operation!
Nov 07, 2010 | Ultra Products Health & Beauty
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code 40
According to the Whirlpool installation and maintenance manual:
F _ _ “F##” code
Press PAUSE/CANCEL once to clear code.
Press START. If code appears again, call for
service.
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
LE indicater
I have had that where the filters are dirty,
check and clean filters at base of dishwasher.
Chris
lg durban
031-7165444
Jan 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG washer code LE or IE showing up
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Nov 18, 2008 | LG WM1814CW Front Load Washer
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
71 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
