Question about LG Dryers
Change from 4 wires to 3 wire receptacle - LG Dryers
  • 28 Answers
This is not recommended, Have an electricion install a proper connection to the dryer
Posted on Aug 29, 2010
  • 1073 Answers
SOURCE: need to change dryer receptacle
do you mean dryer cord
Posted on May 02, 2008
Illeagle
  • 525 Answers
SOURCE: I have a maytag dryer
A 4 wire cord should be hooked up accordingly:
1. Black wire to either outside terminal post.
2. Red wire to the remaining outside terminal post.
3. White wire to the center terminal post.
4. Green wire to the frame screw.
Also, make certain that your breaker/fuse box is wired according to local codes. If your dryer is not properly grounded through the fuse box and the green wire is attached to the frame then, a ground wire would need to attach to the green wire and then to an earth ground. This could possibly be your 5th wire, but you need to investigate it before applying power to the dryer.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • 1028 Answers
SOURCE: wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Posted on Jul 30, 2008
  • 10865 Answers
SOURCE: need wiring instructions to install a 4 prong wire from a 3 prong wire
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
go to this link and you will have your solution
Posted on Apr 20, 2009
  • 351 Answers
SOURCE: trying to convert my dryer from 3 prong to 4 is
Hi .. I am posting a sketch of the 3 wire and 4 wire connections .. if you have any questions please get back to me ..
Posted on Jun 19, 2010
Tip
Rewiring 4 to 3 wire plugs Information.
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
on Feb 09, 2010 | Washing Machines
Wiring diagram for al1430R I have a old 220 volt 2 wire circut. how do i replace it with a L1430R Receptical?
you may as well run a new 4 Wire cord from the panel to this receptacle as its a 3 pole 4 wire receptacle you will need to add 2 wires a Neutral and a Safety Ground wire anyway and you will most likely need to widen the hole that the existing 2 wires protrude from,anyway as old as these wires are they need changing out anyway
Dec 05, 2012 | Dryers
Dryer has a 3 wire cord, house has a 4 wire receptacle, what should be done???
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 21, 2011 | Dryers
I have a 5,500 watt generator that uses a NEMA L14-30 amp, 250 volt 4 wire connection cable. The house I recently purchased has a 50 amp cutler hammer transfer box with a Leviton 5378 50 Amp, 250 Volt,...
The best solution is probably to change the 3-wire receptacle to a 4-wire unit. The 4-wire unit has a ground connection whereas the 3-wire unit has a tie to neutral, but no direct connection to ground. Hope this helps!
Dec 27, 2010 | Garden
I have a hotpoint dryer that has a fire wire plug connected to it. The house i have now has a three prong receptacle on the wall. Can i just buy a three prong receptacle and tape off the extra red wire.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 29, 2010 | Hotpoint Dryers
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Dryers Logo
37 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
