Question about HP DeskJet 9300 InkJet Printer
I have a hp9300 printer that I need to install on my Dell computer. It has a vista operating system.
    Guru:
  • 731 Answers
HP has no printer software for this model for Vista Operating System.Alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer.
Alternate Driver for HP Deskjet 9300 is HP Deskjet 1220C
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2.Click Start , click Settings , and then click Printers .
3.Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then clickNext .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver HP Deskjet 1220C for the printer and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12 . In the printer folder, right-click on the name of the printer and then click Properties .
13.Click the Ports tab.
14.Change the port from LPT1 to the newly created USB port, click Apply .
15.Click the General tab.
16. Click Print Test Page .
Regards
Riztech
Posted on Aug 29, 2010
My new computer, Dell Inspiron 570 will not communicate with my old printer, Dell A940, All-in-One. How do I fix?
Hi Barbra,
Check all connections.
Have you installed the printer drivers?
Try un-installing and installing the printer drivers again.
Was there change in the operating system?[Say you were using windows xp and now you're using windows vista]You may need to install the driver that corresponds with your operating system.You can download the drivers from this link:www.siliconguide.com/drivers/device/583/
Hope this helps.Thanks!
Oct 13, 2011 | Dell A940 All-In-One InkJet Printer
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Vista 64-bit drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
If using Windows 7, use the Vista drivers in the compatibility mode.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
Mar 04, 2011 | Computers & Internet
I have a Dell laptop with Windows Vista and an hp officejet 4215v all-in-one. How do I get the fax and scan functions to work? I can print but not scan or fax. I am not at all computer literate. HELP
First step is to know the version ( system type ) of your Dell Vista PC.
Click on START button
Right click on Computer and left Click on Properties
From the New Window Check for System Type : It will be mentioned as 32 bit operating system or 64 bit operating system. ( Remember this )
I assume you have not installed the complete software for your Printer.
Click on the link below to download the drivers for Vista O/s for the printer.
When the page is open - Choose the Operating system and click on Next Button.
Click on Drivers and Product installation option and click on HP Full Feature Software and Drivers
Click on Download button on top and click SAVE ( Remember the location you save the file )
You need to run the downloaded software.
Disconnect the USB Cable from printer before you start the installation as the screen will prompt you when you connect it.
Download Drivers
Hope this is helpful and will help you in installing the printer software and able to scan as well.
Thank you for contacting FixYa
*Please rate this solution with thumbs up and comment on it
Nov 16, 2010 | HP Officejet 4215v All-in-One Printer
I don't have the installation C.D. that goes to my Dell Printer Photo 964 and I need to install it on my computer
You can download the installation driver from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu. Then download the required drivers and software.
The list of available drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
Sep 21, 2010 | Dell 924 All-in-One InkJet Printer
I download the drivers but when I go to install it says it cannot find them
Depending on the make and model of your computer and operating system, you'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until you're prompted to restart your computer.
Install the proper drivers. You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
If using Windows 7, install the Vista drivers in the compatibility mode. Vista 32-bit for Windows 7 32-bit and Vista 64-bit for Windows 7 64-bit.
Links to the patch/drivers and installing in the compatibility mode can be found at...
924 Photo All-In-One Printer owners thread (W7)
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
When I tried to initially install the software on my new Dell computer for my new and not connected Epson NX110 printer I encountered the following error message: Epson.EXE: Epson.EXE-Bad image Epson Xtra...
the new dell pc comes with vista operating system . the printer drivers u were trying to install is not compatible with the operating system : follow the link or copy paste to download the drivers for vista operating sysytem .
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128284&infoType=Overview
note :
1. make sure u leave no traces of old printer drivers on ur new pc .
2. make sure if u have windows vista 32 bit or 64 bit os ?
3. still having trouble ..
reach me @ http://www.crossloop.com/ironcross
Jul 20, 2009 | Epson Office Equipment & Supplies
Im trying to install an old printer on a new vista comp w/o disks
Windows Vista" is your operating system.
I would start by uninstalling (undoing) any of the printer software that you have installed, and try again. It sounds like at this point that you may have bits and pieces of both 'XP' and 'Vista' drivers installed.
Your link is pointing to the right page at Dell, just select the "driver" under the windows Vista tab.
I'm not sure how that software will be packaged, But I assume that it is self installing once you download it. You just click on it to start the installation. Usually you will leave you USB cable to the printer unplugged until after the installation, and then you are prompted to plug it in.
I'm not sure if this will help, but it's difficult to know exactly what you have done to this point.
Jun 22, 2009 | Dell 942 All-In-One InkJet Printer
Dell A920 with Windows Vista
Hi!
That A920 is working with vista, here is the drivers for thet:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A920&hidos=WW1&hidlang=en&TabIndex=
Dont forget to download and install the application to, you need all the files on that site
For that 968 printer, uninstall it, download the files from the link below and reinstall it, that will make your printer work again
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A968&hidos=WNT5&hidlang=en&TabIndex=
Let me know how it goes
Good luck
Nic
Mar 30, 2009 | Office Equipment & Supplies
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
HP DeskJet 9300 InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
