FixYa.com
Tags:
Sony VAIO VGN-FS920 PC Notebook
Keyboard replacement
posted by mtnjal on May 07, 2008
Need to remove black cover so I can replace keyboard in this VGN-FS920 LT.
Which screws need to be removed? Dis-assembly steps please?
Comment by mtnjal, posted on May 07, 2008
Thanks for the follow up. While waiting I persevered & finally managed to get in. FYI, here are the specifics for accessing keyboard in this Sony Vaio model VGN-FS920 (PCG-7L1L:
Removing battery will expose two flat head screws. Remove them.
Then turn LT around with back facing you. Look at hinges and you will see cover is split horizontally. Pry gently in the split at each end. I found the right side popped apart easiest. Then when room to get fingers under the loosened end of cover, move fingers gently around edge popping the plastic catches loose as you go. When all catches are lose remove cover. There are six plastic catches on back side and nine catches on front so its a struggle. Be gentle, be patient.
After cover is removed, turn LT around with front facing you. Keyboard is held in place with 4 screws at top and one screw in middle. Middle screw is accessible from underside of LT. After screws are removed Keyboard can be rotated toward you giving access to the ribbon connector. Move catches (black)on ends of connector to the left until ribbon cable is loose.
Hope this info will help someone else.
Mtnjal
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
E_wardell
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
Every notebook keyboard that I have replaced is accessed through the top. There is usually a bezel near the hinge that either pops off or may have some screws accessable from inside the battery or other compartment from the bottom. Once the bezel is removed you will see from 2-5 screws holding the keyboard down. Remove those, and gently lift up the keyboard to check the attaching cables underneath. Look carefully at the connectors, some simply unplug others are a ribbon cable that you lift a part of the connector and then the ribbon will come out. Do not pull the cable out!! You may break it if you pull it.
Good luck. I hope this will help.
Rating Locked! (?) mtnjal has rated this solution as Thanks for Trying
Can you Help with these PC Laptops problems?
PC Laptops
pavo
pomagajte molim vas!!!!... Answer This...
PC Laptops
hello
Hello, i read that you have a... Answer This...
PC Laptops
gateway 6860 fx problem with...
When i boot up my computer i... Answer This...
PC Laptops
downloading shader 1.1
Is it possible to download... Answer This...
Installation of audio and video...
I lost my recovery cd. now... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
