Suddenly there are blue horizontal linings all over my screen..even when i start video these linings are acroos them???
    Scholar:
  • 95 Answers
Sounds like your screen is going bad, specifically the connectors along the edges.
Try this: grab the top edge of the screen by the sides, put your thumbs on the plastic at the top and as far towards the middle of the screen as your thumbe will reach. Use your thumbs to push the middle of the screen back from the edges of the screen just a little bit.
BE GENTLE, you should only need about twice the pressure you'd use to press your spacebar on your keyboard.
If one or more of the lines disappears, the screen is going.In some cases, you can get rid of most of the lines by doing this, but they will come back the next time the laptop gets a good bump.
Posted on Aug 29, 2010
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Screen has gone grey and has fine horizontal lines on entire screen. Blue screen is out.
Either the screen voltage to picture tube is more than normal, or the video processor IC has damaged. There is an other possibility that there is no voltage at the video output card, plugged on to the neck of the picture tube. Anyway, your set need a through checkup, and the work is somewhat skilled one. Just check this site. Soemtimes you might get some details about this fault. The fault is called vertical retrace lines. Thin horizontal lines all across the screen with an inch apart. One among the posts published in the following site have details about this fault.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 23, 2012 | RCA F32672SB 32" TV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal lines have recently started appearing in all photos
I just took mine to casio and they repaired it for free even though warranty was up. I would contact them.
Nov 06, 2007 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Horizontal lines
it is due to electrolytic capacitor failure in vertical output section.
just get it replaced.
it very very common & minor problem.
good luck.
Oct 17, 2007 | Toshiba 27AF43 27" TV
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
