Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
F1 flashes on display. Is it possible to buy the replacement part required?
  • 5,081 Answers
1. Check the drain hose and make sure there is no blockage. Also ensure the hose isn't raised too high as water might run back to the machine.
2. Check the port hole and make sure it's big enough for drainage. If not I'll be either bashing it or drilling it out to make it bigger.
3. Reset the machine by powering off the breaker for a few minutes. Turning the power off at the wall doesn't work.
Posted on Aug 29, 2010
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
What does the code F1 mean on a frigidare electrolux 316233852?
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the powericon1.png for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
May 31, 2014 | Kitchen Ranges
On acer aspire5755g lcd flash lines will appear and disappear when clicking on display
Sounds like your lcd is going bad. Try tapping the lcd on the back of the lid and see if the lines flash or appear. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the flash lines then the video card inside the computer is good, but your original lcd screen is bad. If the Borrowed monitor displays the flash lines like your lcd screen then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Computers & Internet
I put my Frigidaire Electrolux oven in cleaning mode an hour ago. It is now beeping non stop with "F1 Err" on the screen. Nothing I push seems to work
If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC).
- If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven.
- If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary.
- If the oven is actually overheating, replace the EOC.
- If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Visit THIS LINK for additional detail
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire oven is displaying F1 on the display case. I had something cooking in the oven and then the breaker popped. I went out to check the breaker box and turned it back on. Now the oven is just...
Visit THIS LINK for additional details.
Hope helps.
Jul 18, 2011 | Frigidaire Ovens
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
130 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
