Question about Electrolux Refrigerators
I have a 430BM and I would like to remove the drain pan above the compressor to clean. Can this be done? if so how?
  • 28 Answers
If it is the unit that I'm thinking it is. You would be unable to remove the pan on top of the compressor because you would have to remove the compressor. DO NOT TRY TOREMOVE THE COMPRESSOR.
If mould is occouring, then, with a funnel pour in a cup of white vinnager, it will kill the mould and eventually evaprate from the heat of the compressor.
Posted on Aug 29, 2010
Does the unit have a drip pan? I pulled the front piece and see the part where it would catch water but it is not removable.
Newer Refrigerators have leaned away from removable drain pans. Most now have the pan built around the compressor motor so that the compressor heat evaporates the water. They could over time develop an odor. Only way to clean them is to remove back cover and use a sponge to clean it. Pull power plug before trying this.
May 19, 2015 | Refrigerators
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
Read the above tip on cleaning your drain line. In it it mentions using a wet/dry shop vac to attach to your drain line. To clean your pan, hook the wet/dry vac to your drain line and flush out your drain pan with several gallons of water until the pan looks clear. You can also add some vinegar to help break up and kill biological growth; however, I recommend flushing it out thoroughly. Try to avoid pouring the vinegar directly on the coil....though if you flush it thoroughly there should be no harm done.
May 24, 2010 | Ruud UBHC Air Conditioner
Water leaking on floor
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Jan 21, 2010 | GE Refrigerators
Water drains into drip pan at bottom of fridge.
You should not be concerned about that. It is a good thing that the water goes to the pan. Depending on your Kenmore model number there is a time set either mechanically or electronically to cause the freezer to go into defrost. The defrost water runs down a small pipe and enters that condensate pan where the fan and heat from the compressor and condenser return the moisture back into the room or home. The problem is only when that drain line becomes blocked is when the real problems happen. Please rate me if this helped you or not rate me if I did not answer correctly y explaining more clearly that this is the subject. You can clean the pan with clorox and water but that requires unplugging the refrigerator and pulling away from wall removing cover behind compressor and wiping clean. The only reason you would need to do that is if food or something spoiled inside refrigerator and that would be done through the freezer and back panel. Ask me later about that. Right now I think you are working fine, Thanks, Sea Breeze
Dec 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a leak from the oil pan ...of my 1992 mercury topaz and im needing to know what all i will need to do to repair it
You didn't list your engine size so please pick the approriate task:
2.0L Engine
  1. Disconnect the negative battery cable.
  2. Raise the vehicle and support safely with jackstands.
  3. Drain the crankcase of oil.
  4. Remove the attaching bolts securing the oil pan to the engine.
  5. Clean the oil and gasket mating surface completely, and allow to dry.
To install:
  1. Apply a 1/8 in. (3.18mm) bead of silicone sealer D6AZ-19562-B or equivalent between the oil pan and engine crankcase.
  2. Install the oil pan using the attaching bolts. Torque bolt to 5-7 ft. lbs. (7-10 Nm).
  3. Lower vehicle, and fill crankcase with correct amount of engine oil.
  4. Start engine and check for leaks.
2.3L Engine
  3. Drain the crankcase of oil, and drain the cooling system by removing the lower radiator hose.
When draining coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze, and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the roll restrictor if equipped with a manual transaxle.
  2. Disconnect the starter cable.
  3. Remove the starter from the vehicle
  4. Unfasten the bolts securing the rear oil pan to the transaxle case.
  5. If equipped with a manual transaxle, remove the secondary air injection tube at the check valve.
  6. Remove the heater supply tube located at the lower water pump inlet tube assembly.
  7. Loosen the bolts and remove the brackets at the block and water pump inlet tube and A/C compressor line at the pan.
  8. Using a prybar between the engine and body of car, flex engine enough the remove oil pan.
  9. Clean the oil and gasket mating surface completely, and allow to dry.
  10. Clean both mating surfaces of oil pan and cylinder block making certain all traces of RTV sealant are removed. Ensure that the block rails, front cover and rear cover retainer are also clean.
  11. Remove and clean oil pump pick-up tube and screen assembly. After cleaning, install tube and screen assembly.
To install:
  1. Apply a bead of RTV E8AZ-19562-A sealer or equivalent, in the oil pan groove. Completely fill oil pan groove with sealer. Sealer bead should be 0.200 in. (5mm) wide and 0.080-0.150 in. (2.0-3.8mm) high (above oil pan surface) in all areas except the half-rounds. The half-rounds should have a bead 0.200 in. (5mm) wide and 0.150-0.200 in. (3.8-5.1mm) high, above the oil pan surface.
Applying RTV in excess of the specified amount will not improve the sealing of the oil pan, and could cause the oil pickup screen to become clogged with sealer. Use ad equate ventilation when applying sealer.
  1. Install oil pan to cylinder block within 5 minutes to prevent skinning over. RTV needs to cure completely before coming in contact with any engine oil. Ideally, about 1 hour at ambient temperature between 65-75°F (18-24°C) is recommended as a drying time.
  2. Install oil pan bolts lightly until the 2 oil pan-to-transmission bolts can be installed.
  3. Install 2 oil pan-to-transaxle bolts. Tighten to 30-39 ft. lbs. (40-54 Nm) to align oil pan with transaxle. Loosen bolts 1/2 turn.
  4. Tighten all oil pan flange bolts to 15-22 ft. lbs. (20-30 Nm).
  5. Tighten 2 oil pan-to-transmission bolts to 30-39 ft. lbs. (40-54 Nm).
  6. Install brackets for A/C compressor line and water pump inlet tube.
  7. If equipped with a manual transaxle, fasten the air injection tube.
  8. Install the starter and cable.
  9. Lower vehicle.
  10. Install engine oil and coolant.
  11. Connect the negative battery cable.
  12. Start engine and check for coolant and oil leaks.
Oct 12, 2009 | 1992 Mercury Topaz
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
To change the oil pan gasket in a 93 Tercel
Stock the car doesn't come with an oil pan gasket but you can order one from you don't have to remove the A/C compressor for any of the jobs you listed. If you want to change the timing belt you need to remove the plastic rock guard under the motor on the passenger side. remove the spark plugs and using the socket turn the engine from the crankshaft clockwise until you are at TDC on #1 cyclinder. (compression stroke) Next remove the upper and lower plastic timing belt covers. The idler pulley is the one with the spring. Loosen the nut and remove the spring then you can remove the timing belt. It really isn't that hard to do. Maybe one afternoon.
Mar 27, 2009 | 1998 Toyota Tercel
How to remove drain pan from compressor
the drain pan removal requires a sealed system repair to modify the type and new location of the replacement drain pan. this should get repaired by a certified refrigeration service technician.
Sep 18, 2017 | Kenmore Freezers
Refrigerators Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
